Omega Help Area => Omega Electrical and Audio Help => Topic started by: jockcmtavish on 07 November 2007, 22:44:24
Title: alarm fault
Post by: jockcmtavish on 07 November 2007, 22:44:24
Basically just goes off when it feels like it sounds for 30 seconds then stops.  Most commonly happens when starting the car but has happened when pulling off from a set of lights!!!! and when it has been parked locked for a while.  The car is not immobilsed tho while it is going off and can be started and driven(or doesn't cut out if it was already running).
Any ideas?
Title: Re: alarm fault
Post by: Marks DTM Calib on 08 November 2007, 12:09:08
Power sounder internal battery failing.....
Post by: tomoco on 14 November 2007, 10:24:58
Yes, sounds like your sounder has duff batteries. Mine used to go off at 3 am. Vauxhall Want 50 quid plus vat for a new sounder. i just disconected mine. As its only a back up sounder ,(just incase somebody disconnects you main car battery) you can unplug it till you get time and money to sort out a new one. You will still have the main alarm horn so your alarm will still sound off.
Mark
Post by: TheBoy on 14 November 2007, 18:15:53
I concur...
Post by: Kevin Wood on 15 November 2007, 00:00:30
Really? That's not too bad actually. Maybe I should replace mine :-/
Post by: Dazzler on 15 November 2007, 00:09:51
I thought thet were about £150 from Vaux and about £75 from Autovaux :-/
