Omega Help Area => Omega Electrical and Audio Help => Topic started by: Spanners_601 on 11 December 2007, 00:18:59
Title: CDR2006 to MP3/Bluetooth unit ?
Post by: Spanners_601 on 11 December 2007, 00:18:59
Ive a CDR2006 Bose system I was thinking of buying an MP3 compatable head unit (maybe bluetooth for the phone as well)
Anybody done this ? I assume that is i buy one with pre amp out I may also be able to get one compatable with the remote on the steering ?
What do I have to do with the facia arond the CDR2006 ? do I remove the cage and buy a new standard din size ? do they sell blanking panels to fit the strange dash shape it will leave behind ?
Thoughts views and recommendations please
Title: Re: CDR2006 to MP3/Bluetooth unit ?
Post by: uktigger on 11 December 2007, 22:48:05
I replaced the CDR2005 in my '03 Omega with the following, which i'm very happy with.
Kenwood KDC 7437U ( http://www.justkenwood.co.uk/stock01/kdcw7537u.asp )
Bluetooth Adaptor (http://www.justkenwood.co.uk/stock01/kcabt100.asp )
Steering controls and display ( PC99-X06-DIS - http://www.justkenwood.co.uk/install/show_model.asp?id=285 )
Dash adaptor ( http://www.caraudiodirect.co.uk/vauxhall-omega-2000-c-292_318_621.html)
Post by: Kevin Wood on 11 December 2007, 23:39:14
If you have a Bose system you'll either have to remove the Bose amp under the parcel shelf and re-wire or devise a way of driving it from the preamp outputs of your head unit.
Post by: jules on 12 December 2007, 08:30:20
If you go with Alpine kit, you can get adapters for the steering wheel remote and the remote display.
Post by: Spanners_601 on 17 December 2007, 20:29:51
Cheers for the ideas guys
.............are you saying that the bose unit is not just a straight forward preamp out from the head unit ? What inputs is it ? is it split channel for channel prior to leaving the head unit ? got a source of info I can refer to by any chance (wiring diagram / block diagram etc.)
Post by: TheBoy on 17 December 2007, 21:52:50
Most makes have adapters for steering controls, and displays...
Post by: Kevin Wood on 17 December 2007, 22:00:54
Yep. Bose amp inputs are not normal line level inputs. The amp takes the signal from the speaker outputs from the CCR2006, which is configured to output a lower level on Base equipped cars.
Not sure if anyone has ever successfully wired a Bose amp to an aftermarket head unit :-/ I would imagine it's do-able but it would require a bit of experimentation.
The other option is to replace the Bose amp with a more generic one (HOWTO guide on here for that). You could then sell the 2006 and Bose amp, maybe theBose loom as well. Always people wanting to upgrade :y
Post by: uktigger on 18 December 2007, 20:55:44
Kenwood HU's have line level out aswell as the normal ISO loom speaker outputs. Just turn internal amp off via the menu to use line out's.
