		Omega Help Area => Omega Electrical and Audio Help => Topic started by: joffy on 26 March 2008, 14:52:06
				have a facelift cdx with 4 disc stacker....radio and tape work fine...but when i try the cd it just says "safe"..can hear internals loading cd when you change disc but nothing plays
 jon
				have you disconnected the battery latlely?
				it happened a couple of years ago.....went to get some petrol...when i got back in the car it was like this!!
 have a single cd player replacement but its a different shade of grey and looks out of place...local place (megavaux) want £100 ouch!
				cd changer and head unit often have different codes. SAFE when using cd changer should mean you need to input the code for it even if you've got head unit working
				If it says CDC SAFE on the CCR2006 then it is a common fault that we can fix for you.
 http://ice.dndservices.co.uk/shop_show_item.php/ST/ccr%202006/IID/587/PAGE/shop_search_index.php
 If sending the unit over to us, send it still mounted in the metal cage as it protects it in the post.
				cd changer and head unit often have different codes. SAFE when using cd changer should mean you need to input the code for it even if you've got head unit working Only on prefacelifts.  The CCR2006 does not provide a way to enter CD code, hence needs to be serviced by a car audio specialist.
				thanx dave....have not had my car for around 8 months as i sold it to my brother....so couldnt remember exactly wot it said....but he hasnt paid me so i`ve got it back...will arrange to get it to you as soon as i have the smashed window and front grille replaced...(he also left it for 3 months on his drive!)..they are a priority
 jon smiles!!
 ah, gotcha
				Dave, do you know what the route cause of these failures is?
 There not using Dallas EEPROMS are they (known to suffer from corruption) or is it just standard Flash based bit flipping?
				Unsure of the Cause - we simply upload a later version of software into the chip and have never seen one back
				I have the same prob on my CCR2006 --- happened, I assume, cos the battery has been disconnected -- radio is fine -- didn't need code re-entering. Is this a unit out and off to DND job .... or as the cause most likely was the disconnection is there another fix ??
				Not connected with battery disconnection - just one of those "things" set to annoy us.
 But in answer to your question, Yes, send it over   :y
