Chat Area => General Discussion Area => Topic started by: Pitchfork on 09 February 2008, 14:39:38
Title: Rover 214
Post by: Pitchfork on 09 February 2008, 14:39:38
My guitarist (Tony Hooper ex-Strawbs) has a problem with his Rover 214 on an 'L' registration plate
About 5 minutes after starting from cold the engine dies & will not re-start
He leaves it for 2-3 minutes, restarts & there are no further problems
Can anyone suggest what the problem might be?
It makes him late for gigs!!
Title: Re: Rover 214
Post by: Golfbuddy on 09 February 2008, 15:02:07
Tell him to leave 5 minutes earlier and he'll never be late again.  ;D ;D
Post by: Tab on 09 February 2008, 15:04:07
^^^ ;D ;D
Post by: Markie on 09 February 2008, 15:16:04
so its wedge shaped rather than bubble shaped...
need more info on oil, coolant condition, service condition, temperature guage readings, idle speed before we can give a decent diagnosis...
Post by: Pitchfork on 09 February 2008, 15:22:00
Oil, Coolant fine. Serviced regularly, Temperature is of course cold when the problem manifests itself & idle speed is around 900RPM, but dies after about 5 mins
It's almost as if it's flooding, or if you were to pull out the choke on an old fashioned carburator type
Post by: VXL V6 on 09 February 2008, 15:27:44
Sounds like it doesn't know that the engine has warmed up and to drop the cold start program. Possibly Coolant Temperature Sensor?
Post by: Pitchfork on 09 February 2008, 15:36:50
But then why would it behave after having been left for a few minutes?
