Omega Help Area => Omega Electrical and Audio Help => Topic started by: rawsondsr on 12 August 2008, 16:22:37
i have the keys, i have inserted them, yet tugging doesnt do owt...
is there a knack?
Same as any other using the double proned keys - insert with u ends slightly towards middle until they latch into place, then pull u ends outwards, and away from dash at same time.
If you've bent the retaining clip by inserting a prone the wrong side of clip, you may have a bit of trouble...
If you are wanting the aerial connector for the Harmon thingy, isn`t there a connector in the kickwell that you can break into without the need for removing the radio?
Others may be able to advise better than I can
Indeed there is :y
driver or passenger side?
drivers
