Omega Help Area => Omega Electrical and Audio Help => Topic started by: Joh on 17 August 2008, 21:19:37
Title: Speakers' slot depth (prefacelift)
Post by: Joh on 17 August 2008, 21:19:37
Hi,
first of all I'm terribly sorry that I'm asking something that has probably been discussed before but I'm really not adequate enough to use this search engine here properly :( Why only 15 matches at maximum? I guess you have many readers in here or something and it'd make the server too slow. Anyway, my problem is that I want to replace my original speakers with some new ones. I know that the front speakers are 60mm deep (however do you call that dimension in English) but the ones I'd like to install are 65mm. Will they fit? And I wouldn't resist if anyone wanted to tell me the depth of the rear speaker slot. Anyway, sorry for being such an a*s, but I didn't find anything on the topic from here :( Nor from anywhere else.. Help would be appreciated  ;)
Thanks in advance,
Your friend from Estonia,
Joh
Title: Re: Speakers' slot depth (prefacelift)
Post by: Joh on 17 August 2008, 21:39:07
Hi again,
I finally found the answer to my question from some Blaupunkt's page (click if interested!) (http://www.blaupunkt.com/au/infoservices_4.asp). So If anyone is looking for the same thing, it's 66mm max depth in the front and 65mm at the rear (I meant the speakers which are inside the doors)!
So, no answers needed!
Post by: bappy on 20 August 2008, 12:27:55
thanks for posting your findings Joh :)
Out of interest, what speakers are you fitting? I have put coaxial alpines in my omega at the front but haven't changed the rear ones. I'd be interested to know how your new speakers perform.
thanks,
ben
