Omega Help Area => Omega Electrical and Audio Help => Topic started by: Cumbria on 23 September 2008, 02:02:26
Thought i would replace the climate control bulbs as 1 had blown can only see 4 though bugger To get to. How do the the wires come off the back of it so i can remove the complete panell do they just pull off. Thanks.
If you remove all switches in hazard switch row, then the connectors behind panel slide out. The climate cables unplug - yellow one has a black tab you pull out first, grey as a sprint clip one side.
Cheers TB all sorted its easy when youve got someone on side who knows what there doing.
alternatively, you can leave switches in place and remove screws holding the climate bit to the rest of the panel and just unplug climate cables. worked for me
some dont seem to have slack to be able to do that
