Omega Help Area => Omega Electrical and Audio Help => Topic started by: steve1 on 21 September 2008, 19:31:51
Title: central locking
Post by: steve1 on 21 September 2008, 19:31:51
central locking not working buttons on key work lights flash but doors do not lock or unlock could it be a fuse or relay.
Title: Re: central locking
Post by: TheBoy on 21 September 2008, 20:04:54
Presumably it locks/unlocks with key?
If so, have you tried resyncing the remote to car (Ign on, press the remote buttons, and car locks/unlocks)?
Post by: steve1 on 21 September 2008, 20:08:16
yes locks with key will try to resync as you suggested.cheers
Post by: steve1 on 21 September 2008, 20:17:20
does not work after resync any other advice wouldbe appreciated
Post by: TheBoy on 21 September 2008, 20:51:15
Did it used to work?  If it is new to car, it needs to be programmed to car
Post by: steve1 on 21 September 2008, 21:59:40
dont no if it used to work,only had car 2weeks,how do you programe it?
Post by: TheBoy on 21 September 2008, 22:01:05
Sadly, thats a job for a Tech2 diagnostic scanner (real one, not cheapo).
Post by: steve1 on 21 September 2008, 22:39:37
could it be a relay or something like that? where can i get an owners manual.please
Post by: TheBoy on 21 September 2008, 22:41:08
unlikely.  Could be a fault in alarm (CD or higher spec) or central locking (GLS) ecu, but more likely a fob fault or simply wrong fob...
Post by: steve1 on 21 September 2008, 22:47:38
what can i do if fob fault or wrong fob
Post by: TheBoy on 22 September 2008, 07:53:31
If faulty fob, repair or replace (replacement will need programming to car).
If wrong fob, it will need to be replaced with correct type, and programmed to car.
If correct fob, and a working fob, but never been programmed to car, this will need to be done.
Firstly, is it a fob integrated into key?  If so, look at the back, and there is a small area that is untextured.  Look carefully (try different lighting conditions) and you will see writing.  What does it say - particularly looking for make, eg Megamos, Delphi, Bosch etc.  Then state what model car you have (GLS/CD/CDX etc)
Post by: steve1 on 22 September 2008, 08:41:33
there is no writing on the fob,on the key there is the number 105 thats all.
Post by: steve1 on 22 September 2008, 08:47:39
opened up fob it is a megamos i have a cd
Post by: TheBoy on 22 September 2008, 08:57:23
Sounds the right fob.
You say the LED lights up, but neither lock/unlock functions work, even after attempting resync (did doors lock/unlock during resync?)?
Post by: steve1 on 22 September 2008, 09:33:16
led lights work,indicators flash when buttons pushed but no lock /unlock,resync did not work does engine need to be running when trying to resync?
Post by: TheBoy on 22 September 2008, 11:04:54
Eh? The car indicators flash?
Post by: steve1 on 22 September 2008, 16:50:50
yes indicators flash once.
Post by: Dave DND on 22 September 2008, 16:55:19
Sounds like its sync`d with the car?
Master solenoid possibly failed or not getting any power?
Can you measure any voltages at the door solenoid when the alarm is armed / disarmed?
Post by: steve1 on 22 September 2008, 17:03:13
hello dave,have no means of measuring voltage :(
Post by: steve1 on 22 September 2008, 17:04:48
also the alarm is not working either
Post by: TheBoy on 22 September 2008, 18:28:13
And locking with key locks/unlocks all doors?
If so, I would suspect drivers door motor.  Time for the meter methinks...
Post by: steve1 on 22 September 2008, 18:59:41
where will i get a meter?
Post by: steve1 on 23 September 2008, 20:13:27
were will i get a meter,please
Post by: markey mark on 23 September 2008, 21:06:00
ebay fella  :y
Post by: TheBoy on 23 September 2008, 21:16:17
when you attempt to lock, does it even attempt to drag the lock down?
Post by: steve1 on 23 September 2008, 21:45:22
no drag nothin,think i have to buy a meter or put in to a sparky to see what the problem is :(
Post by: TheBoy on 23 September 2008, 22:18:13
possibly worth just changing drivers motor with a known good before paying someone to look - guide in Maintenence guides section
Post by: Dave DND on 23 September 2008, 23:04:18
Agree, try changing the motor first - but would suggest against wasting money on a meter if you do not know how to use it, better off buying some beer tokens for your friendly sparky.
Post by: steve1 on 23 September 2008, 23:15:23
cheers,will let you no how i get on.any idea where to get an owners manual?
Post by: TheBoy on 24 September 2008, 08:22:09
Haynes do repair manuals. No brilliant, but useful.  Worth spending a tenner on one from ebay - at Halfrauds prices (£20) bit steep.  If you are on about glovebox literature, again Ebay, or check OOF shop in a few days if I can find any around...
Post by: steve1 on 24 September 2008, 11:55:34
got central locking/alarm working but driver door wont lock/unlock with fob any ideas?
Post by: TheBoy on 25 September 2008, 18:52:18
motor
