Omega Help Area => Omega Electrical and Audio Help => Topic started by: gwa on 06 October 2008, 17:18:33
Title: Light Switch Panel
Post by: gwa on 06 October 2008, 17:18:33
Right, now before I set to with a screwdriver  :-/ how does the panel containing the light, fog & spot switches and adjusters come off?  :-[ I don't want to bu$$er it up so thought I'd post to the experts. Oh, the panel doesn't light so i want to check that its connected then go get a bulb. TIA  :y
Title: Re: Light Switch Panel
Post by: TheBoy on 06 October 2008, 17:56:30
2 carefully positioned knives.
Pop by one day, I shall demonstrate...  ...one of those jobs if you've seen one out, its obvious what you have to do...
Post by: gwa on 06 October 2008, 18:01:11
Thanks TB. Oh, I've had the G/B Switch sorted on Saturday and it now goes like a dream (fingers x'd). I'll run it this week and pop by next Monday if thats OK. Cheers  :y
Post by: TheBoy on 06 October 2008, 18:04:05
Check with me first that I'm in nearer time :y
Post by: feeutfo on 06 October 2008, 18:15:52
couple of credit cards down eiter side iirc?
Post by: gwa on 06 October 2008, 18:26:55
OK ta, it'll probably be post 15:00 when I leave Arncott, or whenever you're in after that.
Post by: gwa on 06 October 2008, 18:27:54
Ha, nice trick. I'll have to steal the wife's Gold Card  ;D
Post by: TheBoy on 06 October 2008, 18:40:32
Same trick but with knives - cards would be awkward.
Post by: MutantCav on 06 October 2008, 19:00:17
Hi TB, for those of us that do not live near you...any chance you can roughly explain the trick to doing this...I know what they look like out the car but is there a specific angle or summat to avoid bending the retaining clips when removing?
Post by: TheBoy on 06 October 2008, 19:26:28
Come in from as high as poss, and get behind the clips, then bring knives forward - ie, trying to depress the clips by coming from behind them.
Post by: MutantCav on 06 October 2008, 19:35:38
So pointyish knives?
Post by: TheBoy on 06 October 2008, 19:43:56
I use the ones that I eat with - just don't tell her ::)
Its a fairly flat/blunt blade, bit like shape of butterknife.
Post by: humbucker on 06 October 2008, 20:42:05
super skinny flat screwdriver works too!  :y
Post by: DC on 06 October 2008, 21:02:31
Just FYI you have a LED and a lightbulb (1.2v) in there. In my case only LED was not working. I soldered a lightbulb instead - cause that is what I had available.
Post by: gwa on 06 October 2008, 21:11:51
Y'know. This really is a very very good forum with some great and knowledgeable members. Thanks all.  :y :y :y :y :y :y :y
Post by: DC on 06 October 2008, 21:32:17
believe me, you aint gonna find better
