Omega Help Area => Omega Electrical and Audio Help => Topic started by: PaulW on 26 October 2008, 00:05:03
Title: GID query...
Post by: PaulW on 26 October 2008, 00:05:03
Reading this guide (http://www.omegaowners.com/forum/YaBB.pl?num=1153215782) it says...
GID for CCRT support - Fitted to all the cars with CCRT radio sets, supports all the functions of the MID in a half height dot matrix display with some dedicated symbols to allow text etc from the phone function to be displayed, only fitted to mini facelift onwards and is coded to the radio unit via tech 2. Has a single grey connector
GID for Nav support - Facelift onwards only, a varient of the above with pretty much the same functions but, not interchangeable. Is a full dot matrix display to support pictgram nav functiosn etc. Has a single grey connector.
Now, is it not interchangeable due to the radio's, or just in general as a whole?? So say I jibbed off the current CCRT stereo, could I use the newer GID still just to display the various info's? (consumption, etc) or is that also not possible??
Also, when the CCRT is not hooked up, how can I go about setting the clock on the current GID?  As the 2 buttons at the top do bugger all when the radio is removed, and I know its updated via RDS when the radio is in place...
Cheers
Paul
Title: Re: GID query...
Post by: TheBoy on 26 October 2008, 10:09:30
Cheers
Paul
For this discussion CCRT display I'll class as a MID, as functionally identical.
MIDs/GIDs/CIDs will all work without radio for FC functions. In the case of GID/CID though, you can't use it, as you have no control buttons for it (doesn't use wiper stalk).
MIDs get time from manual setting (via buttons, or radio only on CCRT), or via RDS (post 19998 only).
GIDs/CIDs get it from manual settings or automatically from GPS.
Post by: PaulW on 26 October 2008, 10:52:32
Fair enough then, thats that plan out of the window!
So in regards to setting the time then, as said when I remove the CCRT, I still can't use the buttons to set/change the time.  Does it need a quick chat with a Tech2 to enable this??
Post by: TheBoy on 26 October 2008, 10:57:03
Actually, if buttons are there, it can be done via them. Not sure if CCRT700 display works without radio though - may have to put MID in (which won't work with any radio)
Post by: PaulW on 26 October 2008, 11:29:26
I'll whip the radio out later then see if they do work without the radio in, but im sure (from memory) they did bugger all last time...
Post by: PaulW on 26 October 2008, 12:28:30
Nope, radio out, the buttons won't change the time.  Aftermarket radio inserted as test, again, no ability to change time :(
Ahwell, I only need to display this bit anyways...
(http://i130.photobucket.com/albums/p266/PaulW21781/507d_1.jpg)
Will figure something out :)
Post by: TheBoy on 26 October 2008, 12:51:07
Throw in a (reliable type) later MID, will work both with wiper stalk, and clock buttons. Will need recoding to match car (eng/gearbox/hids/wheel size etc) for FC functions
Post by: PaulW on 26 October 2008, 13:15:59
Would do, but I'm relocating the display to somewhere else, as I'll be fitting a TFT where it used to be, and as such, I can do away with the clock and date functions, all I need is the various info displays.
Post by: TheBoy on 26 October 2008, 13:34:15
The incoming signals are simple, if your lcd is PC driven ;)
Post by: tmx on 26 October 2008, 16:31:59
CCRT display works without radio  :y also setting time with the buttons doesnt work! :'( thats why my clock is now one hour ahead nvm as  soon it will be going on eBay for my new radio  ::) ;)
Post by: PaulW on 26 October 2008, 17:16:11
All 3 outputs will be PC Driven and shall be running from the same computer :)
Post by: TheBoy on 26 October 2008, 18:45:12
PM me auction link when you put it up - might have a flutter ::)
Post by: TheBoy on 26 October 2008, 18:46:17
All Check control functions are simple 12v/0v connections. Not sure about engine ECU protocol used, you'd need to look into that further.
Post by: PaulW on 26 October 2008, 18:49:07
Well if I could get the data on the consumption/temperature values, I suppose they could all be integrated somehow.
There is a thing called FusionBrain which gives various digital and analogue inputs, aswell as digital outputs to control various things so could route via one or 2 of those...
Post by: TheBoy on 26 October 2008, 18:50:27
Temp would need to go via ADC (joystick input may be useful for this)
Post by: PaulW on 27 October 2008, 17:54:30
Hmmm think I might still keep the GID then, just cover up the time & date sections as they won't be needed & relocate it somewhere...
Post by: Ian_D on 27 October 2008, 22:18:22
Im thinking about doing this with mine - however I thought about linking it to the TPS!
Post by: Kevin Wood on 28 October 2008, 09:31:34
I might be inclined to replace the temperature sensor with a Dallas 1Wire device which you can interrogate by bit-bashing a port (plenty of open source tools available to talk to them). You could place several on the bus and monitor water, oil temperature, etc. too. 8-)
IIRC, the fuel demand signal is just a PWM signal which mirrors injector duration and RPM and Vehicle speed are square wave signals of variable frequency. Not the easiest thing to interface to a PC directly but feed them into a microcontroller to do the time-critical bit and spit the values into a serial port and it's easy enough.
