Omega Help Area => Omega Electrical and Audio Help => Topic started by: mondo76 on 02 November 2008, 17:07:42
Title: rpm sensor fault
Post by: mondo76 on 02 November 2008, 17:07:42
hi all i keep getting an rpm sensor fault coming up , any ideas why?
Title: Re: rpm sensor fault
Post by: TheBoy on 02 November 2008, 17:15:10
Which one, a 19 or a 31?
Post by: ian6pot on 03 November 2008, 17:55:43
Sorry to gate crash this thead but i had code 19 and the opinion of the forum and my opinion also was that it was the crank sensor.
after changing the sensor i still have code 19,the starting problem was fixed by freeing the ICV off so it let some air in on start up but any idear about the code???
Post by: TheBoy on 03 November 2008, 19:06:12
19 means that ECU is unhappy with the signal it is getting from crank sensor. Once fixed, it disappears fairly quickly in my experience.
Post by: ian6pot on 03 November 2008, 19:11:27
Thanks for that,it makes sense.
It carnt be too unhappy though as it runs faultless
Post by: valterferraz on 18 November 2008, 04:03:22
My 2 pence worth.
Hmm. I'll check it out and post here... This problem is quite common among Vectras, Monza/Ascona, and Kadett, that uses the (same?) 2.0i engine.
Buuuut... I have a 3.0L and usually these codes say NOTHING... my car was crazy, not starting, dying and the like. I kind of reset my ECU by unplugging battery for a few hours and that cra* ran well after. Error codes I got: 73 plus 13. Lambda + air flow sensor...
HTH.
