		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Martin_1962 on 28 November 2008, 19:21:11
				Tried a good battery - no
 Jumped a switch - no
 All seems dead - what voltage do those little LEDs take - so I can check that it works?
 If it does and the still doesn't work - what next
 Tracks checked, through thingies checked
				Don't suppose you've got a scanner or similar that will tune to 433.92 MHz? You can hear them transmit if so.
				No scanner (unfortunately)
				You can check the digital sender section with a scope.
 Also, if its the early 2 button job then check the PCB very carefuly for cracks around the battery holder tags
