Chat Area => General Discussion Area => Topic started by: Golfbuddy on 10 February 2008, 21:23:04
Title: Powerpoint Help
Post by: Golfbuddy on 10 February 2008, 21:23:04
I have to do a presentation tomorrow to our board of directors. I have decided to do it in PowerPoint, I know its been done to death but there you are. I have done all the slides and I'm pretty confident of my delivery.
I have a bit of a problem. After the last line of text flies in to screen, all the text immediately disappears with the exception of the slide title.
What do I have to do stop this happening? I've been playing with it for ages and can't get it to work as I want it.
I wouldn't mind but I'm only trying to persuade them to spend in excess of £2million on plant and I think they'd appreciate it if I got the rather presentation right.  ;D
Title: Re: Powerpoint Help
Post by: Auto Addict on 10 February 2008, 21:25:29
Can you put up an example?
Post by: CaptainZok on 10 February 2008, 21:26:37
Don't use animations. ;D
Post by: tunnie on 10 February 2008, 21:28:29
how is the timing set, is there a timing setting on that text object? sounds like it set to 1 second or something.
Remember, no more than 3 lines of text per powerpoint slide. Powerpoint text is an aide, viewers should not be expected to read sentenses on a slide, you just need 'key' words to make your point.
Post by: Golfbuddy on 10 February 2008, 21:29:57
Not sure I can. It's all fairly sensitive stuff (commercially) so not sure I could post anything on a public forum.  :(
If anyone thinks they could help, I could send it as a PM?
Martin  :y
Post by: Darth Loo-knee on 10 February 2008, 21:30:44
Sorry about this Budgie but the only Power Point I know about is the one I fitted into the Garage yesterday so I can plug the lawn mower into it ;D
Post by: JonArgraig on 10 February 2008, 21:33:16
I've to use power point alot for work, like it was said before a example would be great,
Could you not stick up a copy with random text in there ?
Post by: Golfbuddy on 10 February 2008, 21:33:55
I think that's the problem. I can't work out how to set the slide to end on the start of the next slide if you see what I mean.
Some of the slides will generate at least 15 mins of discussion. If I set the timing to say 20 minutes, will it still change when I click the clicker?
Post by: tunnie on 10 February 2008, 21:35:33
You have a remote clicker? then avoid setting your slides to time limits.
Awful way.... you never know what will happen, you may plan 10 mins for this slide, 20 for that. But you could end up doing 30 on a 10.... keep it to a manual method, more control.
standby for photos...
Post by: Golfbuddy on 10 February 2008, 21:36:48
Agreed, how do I get rid of the timings? I don't want to have any restriction on the amount of time a slide will appear.  :y
Post by: Golfbuddy on 10 February 2008, 21:38:27
I'll have a go mate. I guess you mean, do a screen shot and then post via Photobucket?  :-/
Post by: tunnie on 10 February 2008, 21:41:45
to make things easier, group your objects, hold down cntrl, and select both text boxes for title and main text, right click > Objects > Group
Will force all to do the same action, again right click and make sure no animations / timings are set.
To make sure its setup manually:
(http://i97.photobucket.com/albums/l210/tunnie84/powerpoint1.jpg)
(http://i97.photobucket.com/albums/l210/tunnie84/powerpoint2.jpg)
Post by: tunnie on 10 February 2008, 21:43:18
took just 3 mins to shoot and upload  :)
oo eerr sounded a bit off that did  :-/  ;D ;D
Post by: Marie on 10 February 2008, 21:49:13
Right here goes this is what you need to do but please note im on windows 2007 so there are some small differences and hopefully this is not one of them.
1.your need to select the custum aniamation bit.
2. select the text that you want to stop fadeing away.
3.you can ether at this point remove the animation or change the start point to on mouse click.
4. select play and it will show you what this particular slide is doing.
as for the slide changing from one to another you need to slect the advance slide and tell it to do it on mouse click.
sorry if this is vage but i dont know whether we are working of the same version of program if we are let me know and i can go into more detail for you maybe logg on to msn and talk you through it if it helps.
Post by: Golfbuddy on 10 February 2008, 21:59:33
Thanks guys and gals. Nickbat is holding my virtual hand on MSN as we speak. I'll keep you posted.
I'm so glad I'm doing this at 10.00 on the night before the presentation, it's just like a school night over 25 years ago.  ;D ;D ;D
Post by: Vamps on 10 February 2008, 22:07:40
Always best last minute, that is my exuse anyway, good luck with the presentation, you on commission?
 :D :D :D
Post by: Golfbuddy on 10 February 2008, 22:19:57
 :D :D :D
Sadly not, I'm spending not selling.  ;D
Post by: Vamps on 10 February 2008, 22:23:07
 :D :D :D
So it will be a back hander then. ;D ;D ;D Only joking!!!!!!!!
Post by: Golfbuddy on 10 February 2008, 22:44:50
 :D :D :D
It's funny, when you manage a project like this, reps want to take you out to dinner and fly you all over the world to look at their machinery in action. It makes me wonder if they sell anything in this country.  :o
Post by: Golfbuddy on 10 February 2008, 22:56:02
OK everyone. Huge thanks for your input here. Nickbat walked me through on MSN and we had some success.
I'm still not quite sure what's changed but my animations now appear when they should and they stay until I don't want them anymore.
Let's hope they love my ideas now.  :y
Post by: zippo on 11 February 2008, 00:48:23
good luck with your presentation i hope it goes smoothly for you
 :y :y
Post by: CaptainZok on 11 February 2008, 15:43:28
Cmon Budgie spill the beans,did you get a gold star for your homework, or the fatal SEE ME in red ink?
Post by: Golfbuddy on 11 February 2008, 18:42:46
All went very well thanks John.  :y
None of my proposals were rejected and a couple of times I distinctly heard the Finance Director say, 'I quite agree'. Sounds like I might be making a few fact finding visits to Northern Italy in the next few months.  8-)
Post by: Jim on 11 February 2008, 18:44:28
Well Done :y
Post by: cem_devecioglu on 11 February 2008, 18:46:45
Wow..dont forgot your swim suit :y
ps: last night I head big headache and tired so cant help any..
Post by: Martin_1962 on 11 February 2008, 18:50:21
Sounds good, company beginning with B I suppose.
Last big trip any of us made was to Tampere
Post by: CaptainZok on 11 February 2008, 18:55:54
Nice one, can I be the first to volunteer to carry your case on these junkets fact finding expeditions. ;D
Post by: Golfbuddy on 11 February 2008, 18:58:40
Hope you're feeling better Cem.  :y
I've heard that Tampere is one to miss although one of the machines may come from there.  ;D
Post by: Martin_1962 on 11 February 2008, 19:02:22
John went there - two furnace companies :o I can't remember why because they don't take disks!
Post by: zippo on 11 February 2008, 22:22:06
glad it went well martin whats the weather like over there in spring
Post by: Golfbuddy on 11 February 2008, 22:27:14
I'll let you know when if I get there.  :y
Post by: Baron Von Spongebob on 11 February 2008, 22:29:40
Well done Martin.. Lets hope they dont change that to Northern Iraq.. :D :y
Post by: Golfbuddy on 11 February 2008, 22:34:37
 ;D ;D ;D
Let's hope it doesn't also go the way of my last aborted visit.  :'(
