Omega Help Area => Omega Electrical and Audio Help => Topic started by: vauxfan2k on 18 December 2008, 21:28:42
Title: Doing a 4 pot to V6 conversion
Post by: vauxfan2k on 18 December 2008, 21:28:42
Changing a mates 97 16v to a v6 due to engine problems, I have all the parts needed to change his car to a v6,
Engine
manual box (car already a manual)
Exhaust system with heatshields.
Engine and Injection loom
Cooling system
V6 dash clocks and MID
We are not bothered about traction control so is it right to assume that the abs setup can remain the same?
Will we need to change the fuel pump or are they rated the same pressure?
anything else that we havent thought of? (apart from going and buying a miggy thats already a V6)
seeing as all the bits are here and its not costing anything apart from time, we think its worthwhile.
cheers
Title: Re: Doing a 4 pot to V6 conversion
Post by: tmx on 18 December 2008, 21:30:37
i think dont quote me on it but from memory according to my trusty tradeclub book that the p/n for a v6 fuelpump is the same as a 4pot dont quote me on it though! will check the book l8a
Post by: Mr Skrunts on 18 December 2008, 21:38:01
ECU and other Electrics.
Maybe odd bits of plumbing for Air intake and water systems
Post by: vauxfan2k on 18 December 2008, 21:39:55
doh! forgot to add that we have the ecu with the engine loom, ecu has matching chips and reader for barell. also have the prop shaft and v6 diff if needed to keep ratio right.
all water hoses etc are here also.
Post by: markey mark on 18 December 2008, 21:47:24
go for it matety !! should only take a day or two !!  :y
Post by: vauxnut on 01 January 2009, 11:27:33
will front dampers ect need changing due to diff in engine weight.
Post by: ngrainqey on 01 January 2009, 12:18:45
dont think dampers need to be changed, what about the power steering reservoir?
also the diffs arnt the same between the 2.0 and 2.5 but on the 2.5 auto they use the same as the 2.0 auto(3.9 instead of 3.7)-they changed some of the final ratios from 98 onwards ;)
Post by: RobG on 01 January 2009, 12:44:55
V6 and most 2.0ltr models have 296mm front discs. Some of the earlier 2.0 had 286mm. Only 10mm but more braking area :y
Post by: Danny on 01 January 2009, 12:50:45
might be cheaper/easier to just get a completely fresh car!!
Post by: ngrainqey on 01 January 2009, 12:54:11
he apparently has all the bits needed danny.
its not too bad on the later omegas but on mine it was a pain in the arse so i gave it up when i got rather hacked off that it wouldnt crank due to immobiliser box on the early ones with immobilisers that i couldnt find nestled up near the airbag
Post by: vauxfan2k on 02 January 2009, 12:11:18
totally forgot to update this thread, its all done and running sweet, you would never know it wasnt a v6 from factory. did it over 3 days. changing manifold gaskets and all the hard to get at stuff while the engine was out.
We used the 2.0 shocks but the v6 springs as the 2.0 shocks were in better shape.
We also used the v6 diff to keep the ratios right. even changed the MID to keep the fuel consumption right.
was nicely suprised to see that there was no eml light at first start. just shows taking some time makes things easier.
If I had to do this again instead of just going and buying another motor with new problems i wouldnt hesitate.
cheers
Post by: ngrainqey on 02 January 2009, 21:02:57
cheers
the mid should display correct fuel consumption regardless as it goes on the average mpg and how much fuel you have in the tank
Post by: Ian_D on 03 January 2009, 01:32:20
cheers
I thought they were programmed via tech 2, IE a v6 is going to use more fuel than a 2.0, and a 2.0 is going to use more fuel than a 2.5td etc, so it needs to know what it is to display the correct information. :-?
It all depends on how vx's ecu to MID protocols work I guess, which I dont have a clue! ;D
Post by: Kevin Wood on 03 January 2009, 01:35:41
cheers
Correct. The MID gets a signal from the engine ECU based on injector duration, and it needs to turn this into gallons consumed, so needs to be configured for the engine, amongst other variables (using a tech 2, as stated).
Post by: Ian_D on 03 January 2009, 02:36:56
cheers
Aye thats what I thought, Just a quicky... Would that mean changing the fuel rail pressure would result in the MID displaying incorrect information then? Ie, higher pressure, the injectors would be open for a shorter duration, and thus the MID would think that the cars using less fuel, and therefor show higher MPG / Range etc?  :-?
