		Omega Help Area => Omega Electrical and Audio Help => Topic started by: V6CDBOY on 27 January 2009, 10:46:30
				Hi All
 can anyone point me in the right direction.
 Looking to use the reversing lamps as a source of power in the boot which comes on when reverse is selected. I have had a rumage but just need confirmation on the correct coloured wire for the positive cable for the reverse lamp in the loom.
 Any help greatly appreciated.
				Hi All
 There'll be a factory supply for use with a caravan behind the trim at the back edge of the boot. A single wire with a female spade ..... I think it's white/black alongside your round connector that has the other 12N connections.  :y
				Thanks Andy B,
 theorecticaly speaking then as I have a tow bar fitted with electrics it should be possible to wire into to tow bar reversing wire should it  not???
 :D
 :D
 Yes! :y
				Great News!
 Whats the best method for identifying the reverse wire as I don't think there is a black/white wire?
				Great News!
 It's a separate wire from the loom with a female terminal ....... Have you a multi-meter? It'll be live when reverse is selected  ;)  ;)  ;)  :y
				Cant find it...
 .... Am I looking in the right place i removed the spare wheel and I have found the loom. Is this the right place.
				Cant find it...
 No.
 You need to remove the trim at the back (bumper side) of the boot.
				Ah right,
 So I remove the trim covering the rear lamp clusters?
				Ah right,
 NO! :-?  :-?  :-? [size=24]At the back edge of the boot!! [/size]The bit that you rest your suitcase on as you put in the boot!!!!!! It's held on with half a dozen Torx headed screws that are hiding under an oval blank/cover (as big as your little finger nail and some plastic dome headed things that unscrew from a threaded stud on the inside of your boot!
				Sorry Andy B
 thats the panel that I meant the one that holds the boot slam lock panel!!
				Sorry Andy B
 That's the one! I thought I was going to have to drive down to house to show you!  ;D  ;D  ;D
 It should be around there, near where the loom for the number plate light goes through the body.  :y  :y  :y And it's certainly white/black on my preface lift ...... I found a photo I'd taken before I connected up my trailer electrics. (different plug to yours)
				Hi All
 sorry just got to ask. WHY??[size=9](bet it's reverse park sensors)[/size]
				Hi Kris9128
 I'm bein a typical bloke, I've got a camera and the facility on my H/U so I'm installing a camera.
 ;D ;D
 You fixed yours yet?  ::)  ::)  :y  :y
