		Omega Help Area => Omega Electrical and Audio Help => Topic started by: crew18 on 05 February 2009, 18:17:41
				hi
 i have jist brought a r reg omega 2.5 v6 auto and fitted a tow bar and run all the electrics no problem but come to a real snag now i got to the fitting of all the wires
 can any1 advise on what goes to where i have a list for the trailer boat plug
 nearside indicator
 rear fog light
 offside indicator
 offside tail light
 stop light (either side)
 near side tail light
 if any1 know what colour thease wiers are it would be much appreciated
 thanks
 p.s.
 sorry if this doesnt read right it is my 1st ever post  :y
				Standard 12N plugs use:-
 Pin 1: yellow- left hand indicator
 Pin 2: blue - rear fog
 Pin 3: white - earth
 Pin 4: green – right hand indicator
 Pin 5: brown – right side light
 Pin 6: red - brake light
 Pin 7: black - left side light
 HTH :y
				hi
 nearside indicator
 rear fog light
 offside indicator
 offside tail light
 thanks
 p.s.
 There's loads on the forum .... somewhere, you need to dig around.  :y
				hi thanks yeh
 do you happen to know the colours for the car ?
				Saloon or estate?
				hi thanks yeh
 I'll have a look. My loom is a GM loom so I didn't need to know what colours where what.
 black/yellow is brakes ....  ;)  :y
				Having looked through Mr Haynes diags  ....... (feel free to correct me anyone) ::)
 Earth (0volts for the electrickery bods) - Brown
 Brakes - yellow/black
 left tail - grey/black
 right tail - grey/red
 left turn - black white
 right turn - black/green
 rear fogs - black/blue
 You should be able to find all these connections behind the trim at the rear of the boot (bumper side) in a square-ish plug which also contains a bigger red wire for powering caravans.
 NB if you use the brake's black/yellow wire at the plug then you'll need to bridge the terminal in the relay base above the driver's feet or fit the trailer brake light failure 'relay'.
				hi thanks is all working well  :y
				Thanks for that Andy B will needed that info for when i do mine  :y :y
