Omega Help Area => Omega Electrical and Audio Help => Topic started by: Pitchfork on 05 March 2009, 08:57:14
Title: Aerial Booster
Post by: Pitchfork on 05 March 2009, 08:57:14
Do Estates have aerial boosters?
If so where are they located?
Title: Re: Aerial Booster
Post by: zirk on 05 March 2009, 13:38:24
Some Estates (early ones) have booster boxes for the Rear Window Aerial jobby (think the located in the rear door). Not sure about Estates with proper aerials thou, think there wired straight through.
Why do you ask?, common fault on the Estate Rear Window ones are the Coax Cable gets damaged on the loom (inside the gromet) on the rear Door Hinge (easy fix).
Post by: Pitchfork on 07 March 2009, 18:11:34
Because turning on the HRW causes interference which on saloons is alleged to be caused by integral ariel in rear window/booster amp
