		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Shagma on 04 April 2009, 19:21:23
				The fuse for the heated rear window breaks every time i replace it, as soon as i start the engine.
 Omega '97 stationwagon x20xev.
 There might be several reasons for this problem especially since there are other equipment connected to the same fuse, however, my purpose is to get input from other omega owners.
 Locale garage spent two hours troubleshooting, but I decided to try a litle bit more on my own before handing it back to garage....
 Have anyone else experinced this, and what was the reason for this..?
				hi
 what else is connected to the same circuit?
 have you checked for any nacked wires, as they may be causing a short circuit and blowing the fuse out.
 i assume you are using the right size (amp) for the fuse.
