		Omega Help Area => Omega Electrical and Audio Help => Topic started by: Ian_D on 07 April 2009, 11:58:51
				When I lock / Unlock the car, only the N/S bulbs flash  :-?
That’s not too important, but now, they flash for a second, and then remain on (sometimes go off after a few mins, other times it can take 30-40 mins). I have to lock/unlock the car a few times to get them to go off, or pull out a fuse (cant remember which one, but its 20a – 17 rings a bell??).
The car will indicate right fine, but if I indicate left, they light up but don’t flash???
Sounds a bit like a sticking relay, but which one, and where its it!  :-/ Or is it the alarm box having a tantrum? >:(
				could be worth 20 or so presses of the hazzard button.
can sort some indicator issues out  :y
Righto, Will try it!
thinking about it, that was the last thing I pressed when it brokedown on the M42  >:( >:( >:( >:( And they seemed ok before hand!
Tried that, still no joy  :-/
Its just the left indicators which stay on, regardless of the indicator stalk position. If i indicate right, the left ones stay on solid, and the right ones flash.
If I put the hazards on when the left indicator is lit up solid, the right side come on solid too ?
Only way to fix it is to lock / unlock the car a few times until the left side lights go out!  :o
Any ideas?
				hazard switch is goosed!!!! swap it with another to confirm but thats my guess!! :y
Any ideas?
I thought we'd had this on the forum before, and decided that it was a relay sticking/stuck in the alarm .... :-/
Any ideas?
Not sure Andy...
Anyway, its still doing it, and this morning when I went out to it, the battery only JUST had enough power to start the TD.
I got the light to go out by fiddling locking/unlocking it. Got 3-4 mins from home and it came back on >:( So went back for the petrol Omega and ditched the TD one on the drive  >:(
				Anyone got any ideas? Cant really use the car at the moment, and temp insurance runs out on sat  :'(
