		Omega Help Area => Omega Electrical and Audio Help => Topic started by: evvo1 on 26 March 2009, 01:07:38
				Sorry if I missed it somewhere else on the forum, but I can't seem to find any reference to the size of the front door speakers on the facelift models. I've seen a couple of places where the rear door speakers are mentioned as being 5.25" but nothing specific about the front ones. I want to replace my standard speakers at the front with aftermarkets. I have an aftermarket head unit and a sub in the back that I transfered from my old car but the front speakers just don't match up to the rest of the system. I need a better quality mid-range sound to balance it out. Also any recommendations would be welcome.
Cheers
				infinity component' in mine
6.5 inch if  i remember right
good mid range and a bit of bass too
tweeters go in the normal spot  :y
				6.5 is the size of the front speakers.
But I think you'll also need the adaptors to mount them.
				Thanks for that. OK so I look for 6.5 inch speakers then. I may go for a component set and fit new tweeter and xover as well. years ago I used to have a Vauxhall Carlton. That had much better quality speakers than this miggy does??!! I wonder why they downgraded the standard installations? What are the door cards like to remove and re-fit?
				Just a couple more questions: Will most 6.5 inch component sets (Mid and seperate tweeter) be ok just wired straight in, using my present aftermarket head unit? ...It's a sony 4x50w with Ipod connector. I also have an aftermarket rear amp driving a single sub in the back. Other question is: What is the max depth/coil dia speaker I can use in the doors without mods (drilling, spacers etc)? Any data, ideas/recommendations? Thanks.
				As said, assuming a facelift, 165mm speakers will fit but you need a set of Corsa spacers (slanted ones) and need to space the speaker out an additional 5 or 6 mm (I cut out a ring of MDF). Space is VERY critical behind the speaker so speaker depth will be important. I also had to shave away a little material from the door card.
The crossover can be mounted in the space inside the arm rest. Just cut away a bit of the polystyrene filler.
All in all, a bit of a pain, and I'm not sure I'd have bothered if I'd known what I know now.
				Thanks for that Kevin. Yes, its a facelift. Hmm. From what you say it sounds like there isn't a great deal of improvement in the sound quality? ...I also thought of just installing a pair of coaxial speakers and disconnecting the installed tweeters but I cant imagine the sound stage being improved very much by that either. ....Hmmm Maybe I'd be best just leaving it as it is?
				if mounting depth is a problem just cut the magnet off the back of the speaker
nice snug fit after that  :y :D :D ;) :y
Doug
				 ;D OO yeah, great idea! ...Hmm; maybe I could get some with huge magnets, leave em on, and just cut a hole right through the door panel and have them sticking outside? ...Of course, I'd need to fit a rubber seal around the hole to keep the weather out! I wonder if Alpine do speakers with coil magnets in Nocturno Blue to match the paintwork?  ;)
				Quality of the original speakers is not too good IMHO but worth the hassle of changing them? Depends how seriously you take it. IMHO.
A deeper magnet is OK if you don't ever need to wind the window down more than 1/2 way. You'd have to go some to reach the outer door panel. ;D
				if you do change them invest in some sound deadening eg dynamat it improves the sound and stops irritating vibrations :y
plus i would always try and run them of an amp if you can a head units output isnt enough to do them justice and 4x50 is a measurement of its peak power over a very short time you have more like half that running continuously and that's not even a rms measurement (Root means square)true power output measurement
the mid range will be lots better off an amp it is able to drive the mid/woofer properly :y
				dynamat ?
or you could use underseal put on with a brush  :y
it might sound crazy but 2 or 3 coats work great and alot cheaper too  :y
