Omega Help Area => Omega Electrical and Audio Help => Topic started by: Goonybird on 24 April 2009, 19:48:25
I want to wire a small running light into each mirror housing.
So I am trying tio determine if there is a constant +12Vdc feed in the mirror housing, with ignition on. Or will I have to pull apart to wire a feed into the housing.
I have the leccy memory mirrors.
Thank you
if you have memory mirrors, might be a switched 12v at pin 4 on connector to mirror itself.
