Omega Help Area => Omega Electrical and Audio Help => Topic started by: HI2DVY on 04 May 2009, 11:45:41
Title: Siemens ncdc 2013 wiring connector
Post by: HI2DVY on 04 May 2009, 11:45:41
Hi,
I have a NCDC 2013 in my Elite and want to move the Parrot Bluetooth kit from my CDX. When I installed the Parrot in the CDX I used the mute and audio inputs which are normally used by the Trafficmaster system.
Before I pull out the NCDC2013 from the Elite it would be useful to know whether these inputs can still be used on this model - do they exists or are they used for something else? Alternatively, is there a better way of connecting my phone into the NCDC?
Thanks in advance.
Dave.
Title: Re: Siemens ncdc 2013 wiring connector
Post by: VXL V6 on 04 May 2009, 11:58:58
I think you can buy an adaptor that plugs in the pre-wiring for the Parrot kit, if not you'll need to invest in something like an SOT-78 adaptor cable (and try and fit it behind the head unit!)
http://www.lowcostcaraudio.co.uk/lcca/88888/mia/d/autoleads+sot+078+vauxhall+sot+loom/pid/9404439
Post by: TheBoy on 04 May 2009, 22:03:58
audio in and mute are on back. If you have Traffic Master, you will need to fix the Vauxhall half-arsed attempt at making a working loom.
Post by: VXL V6 on 04 May 2009, 22:05:24
And if you need a couple of the missing pins I have some here  :y
Post by: HI2DVY on 05 May 2009, 00:50:32
Thanks TB and VXL. Just needed to know the pins are there and not used by satnav or something.
Post by: TheBoy on 05 May 2009, 11:50:44
The pins are most definately on the back of HU.  If you have external telematics, Trafficmaster, that will also use them, but Traffic Master does have a passthrough facility in the unit, but GM cocked up the wiring in the short TM loom
