Omega Help Area => Omega Electrical and Audio Help => Topic started by: alexgundes on 27 April 2009, 21:39:08
Title: Re: CD-SAFE (CCRT700)
Post by: alexgundes on 27 April 2009, 21:39:08
Switch on ignition,
Radio On
Select CD
Switch off CCRT700 with OI key.
Press hold CD,
Switch on CCRT700 with OI key, keep CD pressed until confirmation beep.
The display shows CD-Code for 3 secs
Then CDC Code ---- (10)
Enter Code
Confirm "OK" by press the muti-function control.
hi there i have the same problem.
well i will try to explain
my cd is not work and i buy another cd changer by philips for my opel vectra B
i do this steps in manual, but it appears CD-CODE, i wait 3 sencods and nothing do. don't appear the chanel for i can put the codes. Its possible to reset the codes? i need help please
Post by: tmx on 28 April 2009, 16:16:54
a phillips cd changer wont work with a CCRT700!
nor will it work in a radio in a vectra B as these use the CAR4/6XX series with a blaupunkt changer
Post by: Dave DND on 28 April 2009, 17:46:59
Very important to get the right model of changer for your head unit, and rememeber that not all CDC2 and CDC3 units are the same either!
Look at the part number on the label, and replace with an IDENTICAL part number. If its different, it ain`t gonna work.
Post by: alexgundes on 28 April 2009, 19:50:38
hi there. it's work fine in ccrt700 on star.
i have one and its work. the problem is:
i try many times de codes and the cd changer/ radio don't accept the code. so in this moment apeears CD-CODE, when i try to do again
almost i am waiting for 3 secs and next apeeats the CDC code ----, and then, i put the code. So this last message don't appers im car.
wha i can do?
i try to put the key in car, and waiting 2 hours to resolve
please help me
Post by: tmx on 28 April 2009, 20:09:00
as DaveDND said please list your CD Changers model number and we can then confirm if its compatible with the CCRT
if its not you wont be able to decode it as the CCRT uses a special changer
Post by: alexgundes on 28 April 2009, 20:13:57
ok
Philips 326599176
No. 09192429
Type CDC3
W1G
Made in Hungary
BS070302
22dc075/78
gmcdc320021158
Post by: tmx on 28 April 2009, 20:19:18
you will have to wait for The Boy to read this as im on the understanding the CCRT700 only works with a special Blaupunkt CDC2 but The Boy know's a hell of alot more than i do about this so will await his wisdom
Post by: Dave DND on 28 April 2009, 22:53:35
I have not seen the CDC3 work with a CCRT700 myself
Unless anybody else knows different?
Post by: alexgundes on 28 April 2009, 23:16:05
this is my car radio
(http://www.erta.ru/base/opel/pic/ccrt700.jpg)
and this is a CDC3
(http://i14.ebayimg.com/06/i/001/43/6e/841d_35.JPG)
Post by: Dave DND on 28 April 2009, 23:45:12
Sorry should have said
I have not seen a CODED CDC3 work with a CCRT700 myself
Post by: alexgundes on 29 April 2009, 00:49:16
Its Works well.
I had my operation, but broke down and had to buy another CD-changer. I put the code several times, and than this error i have appears.
When i not resolve this problem. the cd changer not go work until i resolv and put the correct code. That i put a message in forum to know if was possible to reset all that codes, and start again.
i have try many things. someone tell to put the car key in ingnition and stay for 30 mins or 2 hours, today i leave for 7 hours and nothing do.
i'am affraid to go a office opel and they says me the car must go to a europe officer assistance.
i will  trying everthing.
Post by: tmx on 29 April 2009, 15:55:34
that changers part number is for a CCR600 setup not a CCRT the CODE WILL NOT BE ABLE TO BE INPUT! the changer is the wrong one there are 4 different CDC3's you need one that come of a car with a CCRT700
when you get a CCRT700 CDC3 changer it might not even ask for the code or it will and you will be able to input it
Post by: Dave DND on 29 April 2009, 16:20:20
We have encountered 9 so far across the Vauxhall, Opel and Holden range
You need to make sure you get the right one.
Post by: Andy B on 29 April 2009, 16:40:49
Isn't it a CDC2 that's used with a CCRT700?  :-/
Post by: tmx on 29 April 2009, 16:41:52
Nah andy i thought that so spent an hour last night googling
Astra G & Zafia A had the CCRT700 & CDC3 setup as an aptional extra there were other vauxhalls this went in aswell
there are as dave said atleast 9 different CDC3s about so there is a "special CCRT" variant like there is with the CDC2
Post by: Andy B on 29 April 2009, 16:53:16
I'll look tonight whenI get home, I've posted pictures of what I've got in mine ......  :-/
Post by: alexgundes on 29 April 2009, 16:56:33
hi there i thing my problem is another.
i put many times the code, and the radio ccrt700 was blocked. need do  decoding epprom for the cd canger work again.
Post by: tmx on 29 April 2009, 17:07:26
our Astra CDX has a CCRT but no changer so i should really bodge an omega one onto it but i dont have the time :-[
telephone works though!! :y :y
Post by: Andy B on 29 April 2009, 17:13:48
http://www.omegaowners.com/forum/YaBB.pl?num=1236201616
CDC2!  :y
and I think I posted my picture there too ...... at work so can't see it.  ;)
Post by: Andy B on 29 April 2009, 23:19:35
Just looked .... & I didn't.
So here's the sticker from the bottom of my CDC2 that talks to my CCRT700  :y
(http://i84.photobucket.com/albums/k17/Tiff4327/S73F0306.jpg)
Post by: tmx on 29 April 2009, 23:22:44
same as my Mv6s is that out the Ashtray or the Omega?
Post by: Andy B on 29 April 2009, 23:43:05
Omega 99 Elite.  :y
Post by: alexgundes on 30 April 2009, 00:43:19
ok
but in my case is a CDC3 and works fine.
the problem is another, i put many times the code and the radio is block a CDC need so decoder radio for accept again my cdc3
Post by: tmx on 30 April 2009, 01:25:47
radio locked now?
is it saying CD-SAFE? or just SAFE??
Post by: Dave DND on 30 April 2009, 09:26:02
CDC3 when used with the CCRT700 does not require a code.
If it is asking for one, then it is either the wrong changer or is faulty.
Post by: alexgundes on 02 May 2009, 18:53:28
radio locked now?
the radio is SAYING CD-SAFE. NOT safe.
Post by: tmx on 02 May 2009, 22:19:21
as dave has already said you have the Wrong CDC3 you need one from a CCRT Equiped car not any old CDC3
Post by: alexgundes on 03 May 2009, 22:20:58
Maybe i'am not explain well.
look i am not the wrong CDC3, My car had one CDC3 and its work very well. the problem was, my cdc3 was broken and i buy another one.
I'am not saying is wrong or not, but i garantie that works
Post by: TheBoy on 04 May 2009, 09:58:54
OK, seems to be some confusion here, based around the fact that all UK spec Omegas factory fitted with CCRT700 (ie 1999 CDX/Elites) came with the CCRT version of the 6 disk CDC2.
There is no reason why you can't use the CCRT version of the 4 disk CDC3, as was used in some UK spec Vectra-B
To the OP - assuming this did work once (thus the right CDC3) - are you sure you have the right code, different to the CCRT700 code?
Code input is similar to CDC2, and once you have had a couple of goes, the wait timer starts, initially at 10m from memory, but grows to several hours.  After 10 incorrect attempts, the unit is locked, and needs to be unlocked by a specialist decoding company (not the type selling incorrect codes online).
Post by: alexgundes on 04 May 2009, 18:59:15
Ok thanks.
is true i try many time the code and now is locked, today i go to office OPEL to resolve the problem. My car is a Vectra B (1999), and the radio must go to portugal to be decoding.
Post by: TheBoy on 04 May 2009, 22:04:52
Ok thanks.
Opel can't fix it. You need a specialist car audio repairer
Post by: Sjors-V6 on 06 May 2009, 11:28:48
Indeed thats right !  from each CDC-2 and CDC-3 there are two versions.
(http://i488.photobucket.com/albums/rr246/Sjors-V6/IMG_6022.jpg)
Post by: tmx on 06 May 2009, 11:32:22
they dont understand theres 2 versions weve explained more than 1ce so i gave up!
Post by: Dave DND on 06 May 2009, 13:11:54
Yep, I`m keeping out of this one too now.
 :-X
