		Omega Help Area => Omega Electrical and Audio Help => Topic started by: 2,5v6ukr on 26 May 2009, 17:10:58
				Hello everybody! I need electrical circuitry for ABS unit. For Opel Omega B, 1998, X25XE. Help me please!
				The wiring diag is in the Haynes Book of 'dangle berries', and is probably as good as any.
 If you are after a circuit diagram for its internals, I doubt Bosch would put that in the public domain
				Just seen your location, doubt you get the book of 'dangle berries' :(
 I have a PDF for later facelifts, guess it would be the same...
				Bosch 2SH or Bosch 5.3 system?
				Bosch 5.3 system. [ch8470]0273004206
				Here you go....right click and select "Save target as"
 http://www.bonkerz.co.uk/abs.pdf
 Thanks!
				KillerWatt the requested URL /abs.pdf was not found on this server.
				KillerWatt the requested URL /abs.pdf was not found on this server. I know the file no longer exists, I made the not unreasonable assumption you actually did what I said and saved it to your hard drive.
 :-?  :-?  :-?  :-?  :-?  :-?  :-? HTF do yu save something that's not there? :-?
 It was there when he said thanks, in fact it wasn't removed until the following morning (hence the assumption he had already saved it when he said thanks).
				Its there again now ;D ;D ;)
