Omega Help Area => Omega Electrical and Audio Help => Topic started by: Martin_1962 on 04 June 2009, 13:02:59
1) How to test a coil pack?
2) Can a faulty alternator kill one?
3) Where can I get one from at an affordable price?
Thanks
Martin
Have a 2/4/6 coilpack you can borrow to prove the point if it helps.
Not sure how I would get it to you though? Drop it off at your work fri PM maybe?
That would be brilliant if possible
I'll PM my work address :y
I'll bring 1/3/5 as well.
The coils have some rust on them but they do both work.
Thanks :y :y
All is well mechanically
Getting 0300 0302 0304 0306
What wires do I need to check continuity on from coil pack to ECU?
Thanks
Pin 1 (Brown) to 0V
Pin 2 (Black/red) to 12V IGN (meter continuity to Pin2 on other coilpack as is common feed and other coilpack is OK).
Pin 3 (Blue/red) to ECU Pin14 (X85)
Pin 4 (Blue/white) to ECU Pin15 (X85)
Pin 5 (Blue/green) to ECU Pin16 (X85)
NB. Don't know if you've seen the M3.1.1 ECU connectors but they are a high density design.
Had a bit of difficulty finding the RPM wire - have been in there before.
Thanks - will check tomorrow, light is just starting to go
No change :'( :'( :'( :'(
And completely out of ideas
