Omega Help Area => Omega Electrical and Audio Help => Topic started by: VX1 on 12 June 2009, 17:06:07
Right the next job I have got to do is re-wire the fog lights from the original wiring to the wiring on the facelift fog lights. Now there is only one cable on the facelift fogs but two for the pre-facelift.
What I was thinking about doing was to link up the two seperate cables then run that to the single cable. Is this as easy as it sounds or would I need to have it with an inline fuse?
Paul
If they come from the same point in the fusebox then you should be able to simply join them together.
However if the two seperate wires are thinner then you need to test they are both connected or one thinner wire will take the full load or both lights, which could get warm.
Fogs now working :y
Paul :y
