Omega Help Area => Omega Electrical and Audio Help => Topic started by: zulu one zero on 15 June 2009, 10:48:46
Title: alarm issue after battery change
Post by: zulu one zero on 15 June 2009, 10:48:46
hi all, I've just tried to change battery - old one knackered. followed handbook instructions, but, when new one hooked up, the alarm sounds, & won't stop. the car starts, radio works etc.
HELP!! :o
Title: Re: alarm issue after battery change
Post by: zirk on 15 June 2009, 11:37:59
HELP!! :o
Disconnect the Battery again, reconnect with the Bonnect switch down and recycle lock up / open afew times with your remote.
Post by: zulu one zero on 15 June 2009, 14:10:07
at the risk of sounding stupid (i'm having a senior day today) is that beside the power steering fluid reservoir?
Post by: zulu one zero on 15 June 2009, 14:44:27
thanks mate. I had a quick look around here, I do know what i'm looking for. I'll let you know how I get on. Thanks for the tip :)
Post by: Andy B on 15 June 2009, 15:54:41
Some later cars do have the switch on the driver's side.  :-/
Post by: zulu one zero on 15 June 2009, 16:49:09
mine is on the other side. unfortunately that didn't work. I'm assuming that the power sounder batteries are knackered. Mine has the soldered in type. is it worth trying to source new ones, or do I look for some elsewhere?
Any suggestions out there?
Other than this, the car is running absolutely fine  :-?
Post by: Andy B on 15 June 2009, 17:29:12
.....Any suggestions out there? .....
If you were to just uplug your power sounder & put it at the back of a garage drawer till its batteries have given up, your car would just be added to the list of all the other Omegas that have had the same done to it!  :y   :y  :y
Post by: zulu one zero on 15 June 2009, 18:15:20
sounds like a plan then! thanks for all help/advice given  ;D
I think I'll be back in touch sooner rather than later - couple of other issues have materialised, but I'll get the fault codes first.......
