Chat Area => General Discussion Area => Topic started by: STMO123 on 14 February 2008, 14:33:30
My astra has a slight cluth judder first thing in the morning. Just for one or two engagements and then it seems fine. I found out that this is common on 2004>>>>> astras
http://forum.astraownersnetwork.co.uk/showthread.php?t=13108
I asked the all-knowing one and he told me that, despite Vx claiming it was faulty friction material, it was, in fact, the DM flywheel that was the problem. Armed with this knowledge, I phoned EH and actually got the service manager to admit it was the flywheel and he booked it in for next Tuesday. So far, so good.
Now, the problem:
The clutch judders just once or twice on cold mornings. I took it to Liverpool yesterday and York on Tuesday, it was good as gold.
On the astra site, two of the guys who had replacement clutched had a very bad experience ( ;D) On the first the Vx technician :D put copper grease on the spline on the output shaft. This, of course, immediately contaminated the clutch plate (I can hardly write this for laughing). On the second, one of the drive shafts fell out after a few miles, the AA man said all four bolts were missing ;D ;D
So, do I put up with a very slight judder on cold mornings or do I let Vx have my car?
Tell the truth now
Tell the truth now
Now hes admitted its the DMF get it changed.......reality is they should do it right.....if they dont then the ball is still in thier court so they have to put anything else right
Not sure about this last one.....there are no bolts on the drive shaft at all.....
Tell the truth now
Yes.....but.....I still have two years warranty if it got any worse........ :-/
Tell the truth now
Get it done now.....you will still have 2 years warranty and wont have clutch judder..........its not like its being fitted by RAC windscreens ;D ;D
Lets face it, if you leave it, its gonna get worse not better....
I have seen cases , it becomes worser.
Your decision..
Tell the truth now
Dont know how you kept so cool, I'd have smashed every van windscreen at the depot.
Excellent idea. They need the practice :y
Is the flywheel terminal and only going to get worse or will it just remain a slightly annoying judder every so often?
TBH, if they're going to do it FOC, best they do it ASAP. More chance of any consequential problems being solved under warranty.
One mate from job have 1.6 Vectra C (new model 2004)..
clutch and flywheel is changed 2 times up to now..
Yes Cem. Vx were changing duff clutches and flywheels for.......duff clutches and flywheels.
Then the penny dropped ;D
OK for three days now. Car had been laid up for four months before I bought it so............. :-/
Now, the problem:
its just like its owner you must judder a lot too, first thing in the morning at your age LMAO ;D ;D ;D ;D ;D ;D ;D ;D
Oh and as for the Car sell the heap of crap and get an omega, PMSL, this is the man that told us how unreliable Omegas are ;D ;D ;D ;D ;D ;D
Let them have it i'd say.
Now, the problem:
(http://i111.photobucket.com/albums/n156/stmo987/VSIGN.jpg)
Correct, the Astra H only has one clutch and flywheel....
Been in plenty of car situations where I had a problem with my car and just lived with it. Then it had a knock on affect with other parts. Cost a fortune to fix it in the end. I wish I had fixed it when it first became a problem.
Problem I refer to was a set of warped brake discs on my Ford. There was a brake judder when applying the brake. Nearly a year later it needed new steering rack, new shocks, new steering column joint, new brakes, new wishbones. I’m unsure if they were on their way out anyway but no way to know for sure.
Let them have it while it’s under warranty. Clutch judder..... I can just imagine it wearing out gearbox bearings, etc...
Now, the problem:
touchy lmao ;D ;D ;D ;D ;D ;D ;D ;D ;D :P :P :P :P :P
If you DON'T have it fixed, and in 6 months time the clutch/gearbox/engine(?) fails, then they can easily say that YOU caused the problem by running with a known fault, and so side step the warranty leaving you with a large bill.
Get it done by them, if they do it wrong, they'll have to fix it a second time ... :)
even its not fixed it must be legally recorded that you inform them about the fault on time..
and you have to have a signed paper in your pocket showing the date and problem..
Get yourself a decent car like an, ?????, you just know it's the right thing to do ::)
now I asked a mechanic from opel ..
They know the problem but go within official procedure ..
If the car mileage is low and factory accepts the customer complaint
they change the parts..
Problem : parts are not different from the original :-?
I also must state that women drivers dont have chance..they blame it
in their driving simply ;D
Get it done, you know it makes sense. ;)
Yes they are different, different clutch and DMFW were released by Gm at the end of 2007 with a new part number that superseded the old ones.
will be applied to here late I think..Because the friend said its same.. :-/
Had one fitted on 'man fathers' in Jan.....
The parts were on back order but are now a bit easier to get.
They are different.....
Now, the problem:
PMSL! ;D ;D ;D ;D
good to hear they sorted..
Here new Astra have very high market ratio..
And also the new sedan..
I'm letting all you omega owners boss me around ;D It's going in Tuesday.
