Omega Help Area => Omega Electrical and Audio Help => Topic started by: JK on 05 July 2009, 00:40:04
Title: heater fan is all or nothing
Post by: JK on 05 July 2009, 00:40:04
Can anyone advise me where to look as my blower fan on my 3.0 elite only works on auto or full ,when i turn the fan down to 1 to 7 nothing works ,i can't hear the fan at all ,however on auto [full] it works fine, this is the electronic type , and it does not matter what temp you have it set at, also air con only works on full or nothing ,anyone have any ideas where to look,thanks --JK
Title: Re: heater fan is all or nothing
Post by: TheBoy on 05 July 2009, 21:06:05
check speed controller, bolted to fan (behind glovebox).
Has the scuttle drain got blocked?
Post by: JK on 06 July 2009, 06:23:59
thanks for that ,i will check asap thanks ---JK
Post by: deviator on 07 July 2009, 12:15:03
That normally the problem. You can repair these sometimes. The thermistor blows, buy a new one of the same value and replace it (pence from Maplins). You'll need a soldering iron. If the coil is black or has a chunk missing, it's a replacement I am affraid. Think it was about £30 from VX last time I did one.
Also worth check the pollen filter for signs of water, I've seen the filter cover fitted badly before and it lead to a lot of water getting in as well as blowing this.
Post by: johnboy27 on 23 July 2009, 14:09:21
Mine did this & it was the speed controller behind the glove box.
Got a second hand one for £10.
Best to remove glove box completely so you can see what your doing though.
