Omega Help Area => Omega Electrical and Audio Help => Topic started by: Andyswad on 25 July 2009, 06:39:16
Title: Auto Transmittion control module
Post by: Andyswad on 25 July 2009, 06:39:16
Just got a new one as the gear selector lights are flashing inside the car and 1 and drive are on together,
Where is it situated and is it just 'plug and play' or does anything have to be reset
Thanks
Title: Re: Auto Transmittion control module
Post by: TheBoy on 25 July 2009, 09:27:28
Thats a selector switch problem, fairly common.
Clean/replace selector switch which is bolted passenger side of gearbox
Post by: Andyswad on 27 July 2009, 11:31:44
I.ve bought the damn thing now so may as well fit it, so where is it and is it just a plug in swap?
Post by: VXL V6 on 27 July 2009, 12:32:02
Waste of time swapping the ECU, as TB says, clean the selector switch.
Post by: Andyswad on 27 July 2009, 15:27:11
I know that, but i now have a brand new one that I may as well fit considering the one in the car has been used for 10 years and the alternative is to sell it or put in in the garage.
So i'll try again.
Is it behind the glovebox?
Is it just a straight swap, ie just plug in?
Post by: unlucky alf on 27 July 2009, 17:10:42
the ecu is situated in the drivers footwell on the right & quite high up [by the gas pedal], id be interested how youve got a new one without getting the info off the original? so i cant say if its a straight swap or not  but if the model number etc match then it should be o,k, but i go with the rest & say its the selector switch at fault :y
Post by: TheBoy on 27 July 2009, 19:19:27
does the new one say GS8.20 on it?
Its where Unlucky Alf says.  It **may** need configuring for the car if brand new
