Omega Help Area => Omega Electrical and Audio Help => Topic started by: I_want_an_Omega on 06 August 2009, 17:32:11
Title: Scuttle panel - wiring ok?
Post by: I_want_an_Omega on 06 August 2009, 17:32:11
Hi,
Both my cars have the same "issue" insomuch as the wiring harness cables above the pollen filter have lost their "wrapping". Both cars are S reg an were built within a week of each other.
It looks like the tape has simply disintigrated over time. Apart from putting more tape on - does anyone have any comments?
Title: Re: Scuttle panel - wiring ok?
Post by: Ziad on 07 August 2009, 07:27:49
Hi,
Uh, IMHO, that should do it. you could use a few cable ties in there as well, to make sure the tape does not come loose later
Post by: Agemo on 07 August 2009, 22:14:36
I would like to think I would use something better than tape, just can't think what though. Plastic tubing???
Post by: I_want_an_Omega on 10 August 2009, 22:20:04
I'll be using "self amalgamating" tape available from Maplin.
Will seal into a solid rubber mass once it sets.
