Omega Help Area => Omega Electrical and Audio Help => Topic started by: goonv6 on 17 August 2009, 18:24:23
I've fitted a new engine and battery, came to start her today and nothing. I have all electrical systems working (bar a dodgy passenger side window) I turn the key and nothing, no drop in power. There are relay sounds coming from the throttle body switch but nothing coming from the starter motor. I have looked in the relay box in the engine bay and there is a missing relay in position 2. This has a 30A fuse piggybacked to the side. Could it be this? If so, what relay do I need and where can I get it from?
Check for codes mate - could be anything!
That relay is for headlight washers but the immobiliser light is staying on. I have the code number, is there any way of reprogramming it ?
Is the EML flashing with ign on?
No.
Just realised. You are really local to me. I'm in Wellingborough.
I am getting code 135: telltale checklight voltage low but what does this indicate? How do I rectify this?
Changed the starter motor wiring loom today as that came with the replacement engine and may have seen some abuse but no joy, still exactly the same. I get absolutely nothing on the turn of the key. A mechanic told me that the electronic part of ignition switches on Vauxhalls can go and this may explain why nothing is happening when I twist the key. What do I replace and how do I do it?
dont worry about that code, its not relevent in this case.
replied to pm
Many thanks for your time. Guess what I'm doing tomorrow!
Right, update. Turns out that the starter motor was knackered. I have fitted another one. (And took a chunk out of my leg doing it. Grrrrrr) Its now turning over but its still not starting. Its coughing like it wants to. I'm going to check the spark it getting there.
Right, I have got spark and fuel but still not starting. I reckon its plug order.
...and today she started! WAHOOOO! (I'm a little bit chuffed!)
Many thanks to theboy for being patient and making me reason through it.
