Omega Help Area => Omega Electrical and Audio Help => Topic started by: jereboam on 11 August 2009, 17:35:54
Title: CDC2 changer won't eject magazine
Post by: jereboam on 11 August 2009, 17:35:54
Everything else works fine, but I'd like to listen to something else.
Title: Re: CDC2 changer won't eject magazine
Post by: Dave DND on 11 August 2009, 19:07:10
Does it shuffle through the discs ok?
Does the eject button "click" as you press it?
Post by: Welung666 on 11 August 2009, 20:33:11
[highjack] Mines the same, says 'no disc' even with 6 in the breach, only clicks the first time I press eject. Tried it with the top off and it takes whichever disc in, says 'no disc', press eject and disc moves about a 1/3 of the way back towards the cartridge and stops, clicks then does nothing :( [/highjack]
Post by: Dave DND on 11 August 2009, 23:12:42
So with the top off, does it fully load the disc? Does it spin the disc?
Post by: Welung666 on 12 August 2009, 06:19:54
The disc goes all the way accross, no spinning though.
Post by: Jimbob on 12 August 2009, 07:43:05
when mine did that (several times before i decomissioned it) taking the power lead out the back of the changer would often help an eject, that and / or 30 odd eject presses  :(
Post by: Dave DND on 12 August 2009, 09:03:58
Sounds like a dead laser that cannot determine a disc has been loaded
Probably salvageable though
Post by: Welung666 on 12 August 2009, 09:21:51
I have another CDC2 but it's not the FD type needed to match with my CCRT700. Could I swop out the laser on that or will it be different?
Post by: Dave DND on 12 August 2009, 09:49:33
Laser should be interchangeable -
But have a look at swapping the main pcb over instead - may be easier if the internal wiring is the same - Its the components on the main pcb that allow it to work with different heads, the basic mech and chassis are the same.
Post by: jereboam on 12 August 2009, 11:22:34
Thanks for your response.
The eject button wasn't clicking, but I took the unit out, removed the covers and checked for a faulty switch before my initial post.  I thought it might be a bit dirty, but it wasn't, and when I tested the switch, it clicked, as it does now that I have put it all back.  Probably removing the powe completely caused some sort of reset anyway.  It's possible that the switch is broken internally - maybe I'll dig out my multimeter and have a go, but I'm not sure exactly how to test that sort of microswitch.
As I said, absolutely everything else works fine - it changes and plays the 5 discs in there as perfectly as it always did.  I just can't get the ******* magazine out!
Post by: Dave DND on 12 August 2009, 11:42:47
Check the rear of the switch for dry joints - and follow the tracks on the board to make sure no dry joints on the way. Most of those switches only had two connections on the back, and should momentarily "make" as the button is pressed. I`m fairly sure your problem is dry joints or a knackered switch, as selecting through the cartridge rules out any expensive mechanism faults.
Post by: jereboam on 12 August 2009, 12:33:21
Thanks for that.  I may be wrong, but I rather thought there were 3 wires going to the switch, which was why I was a bit baffled about how to test it.  Anyway, I'll have another look later on.
It's a solid looking and well built piece of kit, isn't it?  Suppose it needs to be to withstand the battering it takes.
Post by: Dave DND on 12 August 2009, 12:44:10
Unusual for three, but if so, two of the pins should show a short when button pressed, and if any are short normally, they should show open when button pressed.
Post by: Welung666 on 12 August 2009, 13:40:06
Yes 3 wires to the eject button (red, white and blue.... how very patriotic!) I've changed the mainboard from the FD that doesn't work to the non-FD that doesn't work and hey presto it works :y Eject button still doesn't work though. Tried both switches and both wire sets in various combinations but still no go. I'll manually pop the cartridge and load it up anyway, I don't change them very often anyway ;D ;D
Post by: jereboam on 16 August 2009, 12:41:10
How do you do that?
As far as I can tell, the switch is working, but it's a bit fiddly to test, as (in the absence of a fully equipped test bench) it needs to be checked in situ.  It needs 3 hands, and as the only available assistant was a somewhat surly, impatient and hungover student, I was not able to spend as much time on it as I would have liked.
For the record, there's definitely 3 wires - one of them seems to feed a tiny LED which flashes when the ignition is off, and glows when the radio is turned on.  What's that for?  No-one can see it without removing a retaining bolt, and nine Torx screws!
Post by: jereboam on 22 August 2009, 15:11:54
Sorry to bump my own topic, but has anyone got any further suggestions?   :) :) :)
Or have I got to take it to somewhere where I have to pay? :( :( :(
Off to Wales on Monday - looks like the cricket will be finished - don't want to have to rely on talking to the wife for entertainment en route. :(
Post by: Dave DND on 22 August 2009, 19:04:59
Sadly, thats the only option left   :'(
Post by: Welung666 on 22 August 2009, 22:18:09
It's a shame you're not passing me Jer', I'd show you how I eject mine ;)
Post by: jereboam on 23 August 2009, 00:48:26
Thanks anyway, chaps. :)
Of course, I could go from Suffolk to Cwmbran via the West Midlands (my brother-in-law always used to go that way, but he's a bit weird), but I really don't think the wife would be too amused at having to sit and watch us tinkering with a car.  And you probably have a job (unlike me) and therefore need to work during the day.
I won't be taking the problem to my regular garage.  Despite hating the Vauxhall V6 engine with great passion, the boss there usually does a good job on the Omega.  But he's the sort of bloke who would have thrived in an earlier time as a village blacksmith.  I don't think that hitting the changer with a big hammer is necessarily the best approach...
Post by: Welung666 on 23 August 2009, 07:11:32
 ;D ;D ;D
I'll do you a little photo HowTo later then ;) :y
Post by: TheBoy on 23 August 2009, 09:50:25
whats wrong with that  :-/
;D
Post by: jereboam on 23 August 2009, 10:23:32
;D
Nothing generally.  However, since that was the first thing I tried, I can say with authority that it didn't help on this occasion. :)
Mind you, after 25 years of running a garage, I expect my friend David has a much better idea of precisely how hard you have to hit the thing to make it work :) :) :)
