Omega Help Area => Omega Electrical and Audio Help => Topic started by: Charlies Dad on 27 August 2009, 09:47:53
may sound daft but the two fans on the radiator, are they both suppose to work?
i only have one working ... fuse maybe ?
2 fans ?????
there should be 2 fans on the front of the rad for aircon and 1 behind the rad for cooling the car hth
Yep, 2 on front of rad run with AC on. 1 behind rad runs when engine is hot.
That is how mine run anyway, never seen just one of the 2 infront run on its own.
Al
Al
Well Al if you want to see one that does your welcome to come and see mine ::) ;D.
Check your fuses in the compartment behind the battery...
