Omega Help Area => Omega Electrical and Audio Help => Topic started by: jake74 on 11 September 2009, 10:20:15
Title: iPod interconnect
Post by: jake74 on 11 September 2009, 10:20:15
Hello!
I've got an old 60GB iPod that I keep in the car with a radio FM transmitter, but I'd like to hook it up with a proper head unit connector, and use the steering wheel controls to select playlists etc.
I've had a quick Google for something, and found this...
http://www.dvbcaraudio.co.uk/connects-ctaopipod003-ipod-opelvauxhall-head-unit-ipod-p-4281.html
Has anyone done similar? Pros and cons?
cheers
jake
Title: Re: iPod interconnect
Post by: Jimbob on 11 September 2009, 10:25:31
interesting.
looks to be only for the old 804 headunit though, if that works with others could see it being popular!
Post by: tunnie on 11 September 2009, 10:29:07
i can't see that working on facelifts because the CD changer is built into the head unit?
Post by: Dave DND on 11 September 2009, 12:42:14
What head unit are you running currently?
Do you have BOSE ?
Post by: jake74 on 11 September 2009, 14:14:32
It is a Bose unit, as far as I know (Bose logo comes up on the display, bose badges all over the show)
Post by: Dave DND on 11 September 2009, 15:50:58
Unfortunately for you, FM modulator is the ONLY option available to you -
With BOSE system fitted, you cannot use aftermarket head units either unless you want to replace amp and speakers as well (speakers are 2 Ohm)
Post by: jake74 on 11 September 2009, 16:26:24
wallet back in pocket. bugger.
Post by: tunnie on 11 September 2009, 17:28:05
are you using a wired or wireless fm transmitter? Wireless ones are pritty shite as the ariel is on the back window.
A wired version is far better, you can tap into the ariel feed behind drivers kick pannel
Post by: jake74 on 11 September 2009, 17:45:32
I'm using a wireless one, and it is crap. I'll have to look see if I can hardwire something in.
Oh, and I don't know what the head unit is exactly, I noticed on the way home it said Siemens NCDC 1020 near the CD slot or something similar.
Post by: Dave DND on 11 September 2009, 20:29:42
I agree that 99% of the wireless modulators out there are useless, and anything that even goes near a fag lighter for its power should be avoided at all costs.
However, I must completely disagree with the wired versions - Although the signal will be piped directkly into the head unit, that is not where I have the problem. The aerial for the radio on the Omega is crap as the best of times, and putting more joints and a circuit board in line are not going to give you a good signal when you want to go back to the FM radio.
We use these modulators, wireless, well built, and 100% reliable
http://www.dndservices.co.uk/am-88t.html
Post by: zirk on 12 September 2009, 02:29:29
Dave, the Guys not asking to change his Head Unit, he just asking whether he can plug his iPod in through the CD changer input with the gadget thing!, at that point the Bose thing is irrelevant,  :y
Post by: bri cox on 12 September 2009, 04:02:20
they should  just plug and play i had no problems with connecting my i pod to my 2006 phillips stereo in my 51 plate elite and every thing still worked ok  and mine has bose  i think i still have the connections somewhere as ive changed my stereo for a double din kenwood tv sat nav jobby
Post by: Dave DND on 12 September 2009, 07:05:48
Not necessarily, I read
As exploring head unit options also?
Post by: zirk on 12 September 2009, 12:52:31
Could both be wrong here mate, but I read as He wants to hook up the iPod through the CD changer input and control the iPod through the Steering Wheel controls?
Seem to remember Ive heard of some Gadget that does this and displays the iPod track info on the screen, but whether the link is the gismo or whether it will work in the Miggy, I have no idea.
Chris.
Post by: jake74 on 12 September 2009, 15:31:24
Sorry for the confusion chaps.
I don't want to change the head unit, just connect the iPod via a wired method, as you could probably tell from the link for the iPod connecter.
So, if I am just plugging in where the CD changed used to plug, I can still use the existing stereo, yeah?
Many thanks!
