Omega Help Area => Omega Electrical and Audio Help => Topic started by: mike1 on 19 September 2009, 14:09:03
Can you help please
I have a 3.0 1994 elite,the hazards work but not the indicators.I have changed the relay and the colombe stick but they still wont work.Is there a fuse for the indicators?
Check fuse #32 under steering wheel
I seem to remember the hazard switch can go faulty and cause the indicators to stop working so may be worth checking if you get no joy with the fuses.
Alternatively just remove the Vauxhall badges and fit BMW ones, you don't need indicators then. ;D ;D
Checked fuse 32 its ok,fuse 32 is the fuse for headlights though!!
R/H main beam and indicators
ar makes more sence now,Still dont work though
Somone mentioned the hazard switch,what should i try with that?
Could try switching on/off about 20 times
Fuse 32 is also for control indicators, I dont see a fuse just for the indicators unless its one of the fuses for the Hazard warning Flashers as there are two fuses no 2 and 12.
it doesnt make any sence having 2 fuses for them?
here is a link that might help a bit.
http://www.omegaowners.com/forum/YaBB.pl?num=1161602008
Whats going on!,I pulled out the fuses then reset the time & date as it went back to 1992,hit the hazzards 20 times still no indicators then for some reason pushed the "rear screen heater" button & the indicators started working!!!!!
After i calmed down i tryed them again and they did not work till i pushed the rear heater button again!!!!!!
