Omega Help Area => Omega Electrical and Audio Help => Topic started by: Humpy on 20 October 2009, 16:38:15
Title: Air Con Doesn't Work
Post by: Humpy on 20 October 2009, 16:38:15
Just bought another Omega for the missus and the air con doesn't work. I looked at it before but realised the air con didn't work (amongst some other niggles) and walked away. When the price came down to what I wanted to pay I bought it! Now a mate, when I mentioned about the air con said that the compressor won't cut in if there's no gas in the system. Is that right? The light comes on the switch but I can't hear a relay. Is there a relay? I checked the fuse and that seems ok, I see on another thread that there's some big fuses for the air con by the battery? Any advice would be welcome, thanks.
Humpy
Title: Re: Air Con Doesn't Work
Post by: Andy B on 20 October 2009, 16:40:03
.... Now a mate, when I mentioned about the air con said that the compressor won't cut in if there's no gas in the system. Is that right?  .....
Correct!  :y
Post by: Dave DND on 20 October 2009, 17:29:36
Can`t speak for your neck of the woods, but around here, Kwick-Fit are about the cheapest for re-gassing
Last one I had done was a VW Sharan - cost me £30
Post by: Humpy on 20 October 2009, 21:44:13
Thanks guys, I'll give it a go then :y
Humpy
Post by: dbug on 20 October 2009, 21:47:55
Didn't they break it up Dave?  Kwikfit are well known for that - they managed one of ours as well as a lot of other members' cars!!  Best to get an A/C expert - we use a mobile guy just as economic as Kwikfit but knows what he's doing!!
Post by: Rockhampton on 20 October 2009, 21:49:02
Most likely to be lack of gas, but low coolant level will also stop the compressor kicking in :y
Post by: Humpy on 20 October 2009, 22:48:47
As in low engine coolant? Why's that then?
Humpy
Post by: Rockhampton on 21 October 2009, 08:04:29
I noticed this originally a few years ago with a Fiat - the heater matrix was leaking, and when the coolant dropped below a certain level, the compressor would no longer kick in until topped up. I had my Omega serviced a few weeks ago, and during the service the coolant was changed - when the car was running with the coolant low (and the coolant check warning on the MID), the compressor would not run - as soon as we topped it up to minimum, it started. :y
Post by: Marks DTM Calib on 21 October 2009, 08:30:51
There is some coincidence there then as there is no connection betweeen the coolant level sensor and the aircon operation.
Post by: Rockhampton on 21 October 2009, 09:09:35
Perhaps so - there was no conicidence on the Fiat as I traced it out on the wiring diagram and the climate ECU did check the coolant level sensor as one of its inputs.
Don't know for certain on the Omega - but JamesHoleinblockV6 was there when it happened!!! :y
Post by: Andy H on 21 October 2009, 11:12:20
My pre-facelift (A/C not climate) used to start the ventilation and compressor as soon as you started the engine. My 2003 facelift with climate control seems to delay starting the ventilation for some time after starting the engine. Don't know what it is waiting for :-/
I don't know whether this is evidence for 'coincidence' or some link between the climate system and the MID/ECU/warning lights that isn't apparent on the wiring diagrams :-/
Post by: Marks DTM Calib on 21 October 2009, 11:30:07
Its because its a more advanced setup, there is little point in winding up the ventilation if you want heat and the engines just been started.
An Omega has no connection between coolant level and aircon.
Post by: espen22 on 22 October 2009, 07:24:49
I would have checked the connections underneath the car, there is two plugs going into the aircon pipes that measures pressure and temperature on the system. theese connectors are wery exposed to destruction if the car is driven without the bottom engine plate!
And on the older models the wirings are bad, they intend to break near the connectors causing bad connection.
If this connectors are ok, i would also given one of the fillvents a little push to see if there is some gas in the system, if totally empty you might have a leak somewhere, and that leak can be in one of the quick connectors located around the system.
