Omega Help Area => Omega Electrical and Audio Help => Topic started by: Agemo on 11 December 2009, 20:22:33
OK gents, I have found I have a headlight out, no problem me thinks, probably just a bulb. Oh no! I have Xenons! Where do I start? Do I need ballast pack? Resistor? Could it be faulty connection? Where do I begin?
Just change the bulb with the one on the other side .. that you know works.... if it works in the failed side you need a new bulb. If it doesn't you need something else .. but my money's on the bulb .. :)
OK Mate, thanks for that, will give it a go. :y
D2S bulbs are needed and they ain't cheap ... this place is "reasonable"
http://www.autobulbsdirect.co.uk/HID-D2S-Gas-Discharge-Bulb-Lamp-Osram-4100K.html?page=1
You can buy cheaper .. but I like Osram or Philips ... :)
Been out to look, but it's like Siberia up my drive. Will have a go 2moro. Thanks for the link, I saw a facelift in a scrappy & never thought of needing the bulbs - DOH!
