Omega Help Area => Omega Electrical and Audio Help => Topic started by: tomoco on 08 January 2010, 14:15:29
My ash tray bulb has gone. how easy is it to replace?.
It looks as if i.ve got to remove the radio to get to it.
I know its probably simple but these tiny things are usually the most annoying.
Many thanks
Mark
Dont know if there the same on the facelift, but poen ash tray take out tray should be a hole at the back, use a long small phillips undo the screw at the back and pull ashtray out, change bulb, refit. :y
facelift and prefacelift - similar concept:
remove the pop-out part of ashtray
in middle at back of open ashtray is a hole for a long philips
Thank you :y.
