Omega Help Area => Omega Electrical and Audio Help => Topic started by: stevi1983 on 06 December 2009, 01:22:13
Title: Left Side Speakers
Post by: stevi1983 on 06 December 2009, 01:22:13
Hi
Got the radio working in the car, but for some reason only the drivers door speaker and the right passengers door speaker works, the two on the left hand side dont seem to work
anyone any ideas
Title: Re: Left Side Speakers
Post by: rustym95 on 06 December 2009, 02:43:42
it might be the speakers but could allso be the flex bettween A post and door, i would say the door wire. :y should un screw, give a good clean and check the wires. :y
Post by: p j morgan on 06 December 2009, 02:47:58
think you should pull the radio out and try and reset the plug that goes in the back of the radio ?more than likely the plug as not been pushed right in!good luck and hope you sort it :y
Post by: Dave DND on 06 December 2009, 08:48:20
Always try the balance control first
Post by: Marks DTM Calib on 06 December 2009, 12:46:15
Absolutely.....check the balance control
Post by: stevi1983 on 21 January 2010, 20:58:47
Ahh, got it fixed, it was the balance controll, should have read the manual first, did'nt relise you had to pull out the voluame controll to adjust the ballance. What a TIT, had the door panels off etc. Leason learned 2 month later...............
Post by: Dave DND on 21 January 2010, 21:06:24
 :-X   ;D
Post by: mathewst on 22 January 2010, 08:33:04
This is probably the 100 problem with the same solution ;D
Dave it is easy to be an expert when you have problems like this :D
Just kidding of course.
Post by: Dave DND on 22 January 2010, 09:43:07
Shhh !!      ::) :P
