		Omega Help Area => Omega Electrical and Audio Help => Topic started by: oceansoul on 21 January 2010, 18:22:47
				into a corsa B. How hard? Whats needed? Mod's to the MFD obviously and can be done.
				Load of wiring, somehow fit mic and aerial, and find a way to mount the display in a corsa display's case.
Once you have the wiring diags, fairly straightforward I would think.
Display may need some tech2 work to flick into TID mode, unless the corsa has check control.
				No the corsa has the older 8 digit MFD so the TID from omega/Vectra would need to be put in place. Or do you mean the original TID would need to be tech2'd to stop it looking for Check control (or whatever it does)
The CCRT display would need to be Tech2'd to act in TID mode.
Does the ccrt700 not come in TID mode in the omega?
its the display, not radio.
				I can understand doing this for a factory look but it does seem a little complicated. The CCRT isn't the greatest of units to start with.
