Omega Help Area => Omega Electrical and Audio Help => Topic started by: unlucky mark mv6 on 03 February 2010, 12:43:35
Why is my rear blind wiring plug in the boot a different fitting to the actual plug on the blind from a facelift elite.Did they change the loom at all even though both cars are facelift. :-/
Early facelifts had the same plug as pre face then for some reason the later facelifts were fitted with a different connector as you`ve just found out :D :)
Cheers rob,i thought i thought i had copped for an oddball miggy for a minute. ;D
Had the same when I moved from an X plate facelift to a 53 plate ;D
