Omega Help Area => Omega Electrical and Audio Help => Topic started by: Edd on 03 February 2010, 12:51:02
Title: heater matrix pump
Post by: Edd on 03 February 2010, 12:51:02
hi all, anyone got a wiring diagram for the hear matrix pump on thhe v6 2.6 or know what fuse it comes off please.
Title: Re: heater matrix pump
Post by: RobG on 03 February 2010, 12:54:09
Flow through heater matrix is controlled by vacuum :-?
Post by: Jimbob on 03 February 2010, 12:55:25
and on some, an extra 12v water pump :y
Post by: Edd on 03 February 2010, 12:55:43
ive got a pump on mine, sits just under the expansion tank ?
Post by: Jimbob on 03 February 2010, 12:56:15
yes, on quite a few, but not all
part of winter pack
and on a lot of MV6's
Post by: Jimbob on 03 February 2010, 12:57:22
what is the problem with yours?
they are controlled by the climate ECU, but unsure of fuse...
Post by: Jimbob on 03 February 2010, 13:00:18
http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
and
http://www.omegaowners.com/forum/YaBB.pl?num=1161602010
may help  :y
Post by: Edd on 03 February 2010, 13:00:27
wasnt getting much heat in the cabin so flushed the matrix and whilst at it i looked at the pump which needed a good clean as it was seazed. all free and runs now but not getting a signal to run even though i have the heat on full in the car
Post by: Debs. on 03 February 2010, 14:06:27
I have an aux. heater pump, the car has aircon but not climate-control: oddly, the pump simply has a 12volt feed with ignition-on or accessory key positions......mine seized-up also.....Fuse is F15 (20 Amp.)
Post by: Andy B on 03 February 2010, 14:32:48
I have an aux. heater pump, the car has aircon but not climate-control: oddly,  ....
I have climate but no pump!  :-/  :-/  :-/  ;)
Post by: tunnie on 03 February 2010, 14:40:04
Winter pack was available to all spec levels i guess?  :-/
Post by: Andy B on 03 February 2010, 14:46:00
What else was included in the winter pack then?  :-/
Post by: Edd on 03 February 2010, 14:59:04
Thanks, will check the fuse now  :)
Post by: Edd on 03 February 2010, 15:03:26
not the fuse  :(
Post by: Edd on 03 February 2010, 15:06:03
but have now found another of these pumps although a different part number that looks like its circulating water from the bottom to the top of the rad ( or the other way ) and that one is completely seized so need to locate a new one
Bosch 0392020034
Post by: Debs. on 03 February 2010, 15:18:10
 ::) Judging by my car, a comprehensive list comprising: an ineffective aux. heater pump, rubber tyres and glazed windows.  ;D
Post by: Andy B on 03 February 2010, 15:33:02
 ;D  ;D  ;D  ;D
Post by: Edd on 03 February 2010, 15:44:09
ok sourced one on the bay from a guy breaking  :)
Post by: Kevin Wood on 03 February 2010, 18:00:38
I believe the pump only runs when the climate is turned on with the engine stopped. It is to allow "residual heat" from the engine to keep the car warm.
On a misconfigured climate panel (configured for no pump present) it runs all the time the ignition is on.
The electric pump by the radiator is to circulate coolant when the engine is stopped. It only runs when the engine has been stopped and the temperature is high enough for one of the fans to cut in. It circulates a little coolant to stop after-boiling.
Post by: Entwood on 03 February 2010, 18:04:29
Thats how it works on mine .. :)
Post by: Jimbob on 03 February 2010, 18:43:14
iirc facelift can use the pump like that, it just speeds heat up on prefacelifts
Post by: Edd on 03 February 2010, 20:10:09
Thanks for the replies there guys, ill check what you have put jimbob and see if it runs then. As for the other pump, i could have saves £25 quid. Oh well may as well fit it now when it arrives
