Omega Help Area => Omega Electrical and Audio Help => Topic started by: unlucky mark mv6 on 12 February 2010, 20:26:45
Title: Switch illumination
Post by: unlucky mark mv6 on 12 February 2010, 20:26:45
In the past i have changed the little illumination bulb in the dash switches in a vec b.Can you change the ones in a preface mig(dash switches). :y
Title: Re: Switch illumination
Post by: Welung666 on 12 February 2010, 20:36:05
Yes but they're fiddly
Post by: unlucky mark mv6 on 12 February 2010, 20:39:21
Yep iirc they are soldered in arent they lee,also will the heated seat switches from the preface cdx fit in the back of a facelift elite. :y
Post by: Welung666 on 12 February 2010, 20:40:56
I can honestly say I've never been in the back of a mig so no idea ;D ;D
EDIT: sorry, yes they are soldered in.
Post by: unlucky mark mv6 on 12 February 2010, 20:43:37
Quite stupid though really being soldered as its a bulb and bulbs often blow. ::)
Post by: Welung666 on 12 February 2010, 20:51:11
It's so a 'trained Vx mechanic' can suck air over his teeth and charge you for a new switch nstead of a bulb ;D ;D
Post by: Dany on 12 February 2010, 21:56:05
And this switch is 38€ + Tax, so 46€ by Opel here in Belgium...
PS: Thankx for your post Mark ;)
Post by: Dany on 12 February 2010, 22:18:21
Here are some pics!
The switch...
(http://img35.imageshack.us/img35/7104/12022010664.th.jpg) (http://img35.imageshack.us/i/12022010664.jpg/)
The connector...
(http://img18.imageshack.us/img18/2765/12022010665.th.jpg) (http://img18.imageshack.us/i/12022010665.jpg/)
The two bulbs inside... (one greater than the other)
(http://img694.imageshack.us/img694/2195/12022010661.th.jpg) (http://img694.imageshack.us/i/12022010661.jpg/)
You can see all is soldered!
(http://img10.imageshack.us/img10/6853/12022010660.th.jpg) (http://img10.imageshack.us/i/12022010660.jpg/)
Post by: I_want_an_Omega on 14 February 2010, 20:18:24
NO. The front seat switches are proper switches & take the full load current (bout 5amps). The rears are used to control relays so that the seats cant be left switched on & reset themselves each time the ignition is switched off.
In short they are a different part. Sorry about that
