		Omega Help Area => Omega Electrical and Audio Help => Topic started by: tunnie on 12 February 2010, 21:01:27
				How long does it take for CCR2005 to 'loose' its code? Just changed the battery on father tuns 2.2 (was original! lasted 9 years!  :o)
 No battery was present for a good 30 seconds to 1 min, it did not need the code entering, and it remembered all the radio stations  :)
				I swopped one recently and it was already decoded.
 So when reinstalled it worked ok and kept the pre-sets.
 Maybe yours is the same. :y
 Mick
				2005's are coded to the car when fitted, don't try fitting it in another car though as it will lock it solid!
				nah its not been decoded, had since it was new, was a company lease car which was purchased when the scheme was canceled. Its about as factory standard as you get, and the radio has never been taken out / tampered with at-all
 You can fit them in other cars, just enter the code. Its the NCDC 2013/2015's which are paired to the cars immobilisers and useless in other cars....
 I was close ;D You can fit it in another car and enter the code but it won't ask when you refit it to the original car then ;)
 NCDC not paired to the immobiliser but generally uses the same security code  ;)
 Nope, wrong on both counts.
 2005 is NOT paired to a specific car, and will need its 4 digit code entered when reconnected, irrespective of the vehicle its going into.
 Not uncommon to retain its memory for near 10 mins though, but that is certainly not the norm.
 Correct, its a bit of a hybrid system - whilst the later CAN stereos are indeed paired to the actual car itself, the NCXX stereos are simply paired to each of its own components, head, changer, telematics etc, all of which are paired together using the same pairing code from the original vehicle
 cdr500s normally retain radio stations (after a search) whilst changing battery. Suspect 2005 will be same.
 Should ask for code, unless code disabled (Please read the manual!)
 No need, got this place  ;D
 Don't re-call the code being disabled  :-/
				Took battery off to charge over night put code in, in the morning done the same again didnt need code?????? :-/
				I changed my battery last weekend. Same CCR2005 model. Snapped the battery retaining plate bolt off when undoing. I filed it flat, centre popped it, drilled it out, tapped it swapped the battery. Reconnected up and my head unit didnt need a code and remembered all presets!! Must have been disconnected well over 15mins. Was expecting a decode bill 4 sure - as I had no code when I bought the car.
 Actualy, the later CAN bus setups arnt paried to the car either. I have done loads of testing for that on my mum bus with a CD30MP3 and CD70
 They are paired to the Display, Bluetooth (if fitted), DAB (if fitted) and thats about it.
 They do have the chassis number entered into them but, this can be changed with Tech2 easily (and is also a method for getting the security code from a friendly dealer !  :y) and none of the other body systems check this.
 Which reminds me, Mr DTM, I have that CD70 for you to test, and ensure is in delivery mode for me :y
 Made that loom yet?  ::)
 So if the head unit has the chassis number of the car programmed into it . .
 . . . . . That makes it paired to the car, doesn`t it ?
 Agreed its not the most secure pairing, but it still pairing, and if the chassis number in the stereo is different, it won`t work.
 Can't get the CD70 to work with an Omega display.
 I'm guessing MDTM means that it doesn't actually check the VINs as part of security coding...
 Thought the loom was for that spare NCDCxx you wanted to test?  :-/
 Whats that got to do with the CD70 I was referring to in this thread?
				nothing... just asking if you made that loom yet  ::)  ;D
 No, chassis number is only in the display or maybe it was the headunit but (cant recall), its only in one of them. The software on any of the units or even the vehicle does nothing with respect to checking chassis numbers (I ran mine for a few weeks with the wrong chassis number as a check)
 The only thing they do is the same as the NCDC's...they check the pin number (or at least an encoded version of it) when turned on.
				Nope, disagree completely
 Chassis number is in both display and head unit, as is the PUK code, but is often encrypted, and not always shown as a straight 17 digit VIN. - depends on software version of head unit.
 Some of the Delco head unts can have VIN number stored in up to three locations also, and one of these will always be encrypted.
 Ok, well thats put some T2 facts in here then to get the in car findings (and clearly, when doing some of the programming, the unit firmware may well place some of the info in multiple places).
 T2 only gives access to programming (and re-programming) VIN number on one of the units. This is how I un-paired my second hand set as I read the VIN number with T2 and then ordered the PIN number from Vx based on this info.
 I ran my setup, having not un-paired or changed the VIN number on it for 2 months and hence it was effectively 'alien' to the car but, no faults were reported on any other systems and it functioned perfectly.
 Once I got round to getting the PIN number I simply went in and unpaired the setup (whilst fitted in the car), then re-paired it using my vehicle PIN and then changed the VIN using T2.
 The only change is it now has the correct PIN for the vehicle and VIN is updated to match the chassis.
 Job done.  :y :y
 Job done.  :y :y
 From your descriptions, I`m guessing that you are using a very early Blaupunkt CD30 ? It has virtually zero encryption and the data can easily be viewed.
 Some of the later ones will require you to monitor the CAN data communications as well, and you will find that the Tech2 is exceptionally limited in what it can analyse.
 Job done.  :y :y
 Nope, tested using a 2007 CD30 MP3 and a 2007 CD70 (dates taken from radio label).
 Both used with a CID and GID  :y
				Actualy, the later CAN bus setups arnt paried to the car either. I have done loads of testing for that on my mum bus with a CD30MP3 and CD70 . . . .
 . . . . Once I got round to getting the PIN number I simply went in and unpaired the setup (whilst fitted in the car), then re-paired it using my vehicle PIN and then changed the VIN using T2.
 Not disputing how they are programmed using the vehicle pin number, I`m disputing the fact that you said that they are not programmed to the car.
 So why do you need the vehicle PIN number to be entered then before it will work in the car?
 To me, thats a paired unit !!   ::)
 In the early days of swapping these around, the heads and displays were sold as matched pairs, and it was found that they worked fine together, and in a vehicle without the need for any PIN codes to be entered. However, there is a very dark and expensive downside to this - when connected to Tech2, and a particular application performed, the unknown pin and radio details from the new radio could actually be irreversibly transferred to the rest of the vehicle meaning that future interrogation of Tech2 could no longer be performed as the vehicle PIN code had been altered and is now effectively unknown. It can be a four figure job to put right -
 Should you be amongst the many in this situation, we can now rewrite many of the ECU`s affected, but not all.
 There not though, if they were then the BCM, REC, UEC, ECU etc etc would be looking at the radio or display PIN (or the VIN) during power up (e.g. ignition on) and blocking the functions off. It does not do this outside of the radio/display (plus ancillaries e.g. DAB and Bluetooth) and hence from a security perspective, sits as a standalone setup.
 Hence its not coded to the car.
 And if somebody was insanely incompitent with Tech2 and did blow the pin through (I will double check but not seen a function for VIN/PIN alignment) then again, its simply a case of getting the PIN from Vx using the (in-correct for the vehicle) VIN number and reversing the damage.
 Simples!  :y
 Simples!  :y
 I think we`ll agree to differ on this one.   :-X
