Omega Help Area => Omega Electrical and Audio Help => Topic started by: ScaniaV8 on 23 February 2010, 16:15:37
Title: Passenger front door lock - key stuck !
Post by: ScaniaV8 on 23 February 2010, 16:15:37
aaaghh.... decided to open the car via the front passenger door lock using key....it unlocked the door but the key will not come out of the door lock. It looks like it's stuck at an angle and I'm frightened to force it either way in case it snaps.
Any suggestions as to how to remove and what's likely to have caused this to happen?
I still have the spare key to gain entry to the Drivers door and the central locking is working ok on all 4 doors  ;)...it's just the key cannot be removed from the passenger front door lock ! :'(
Title: Re: Passenger front door lock - key stuck !
Post by: Mr.Salvador on 23 February 2010, 16:23:17
hmm..might be the cold bud, have you tried WD40? hope you havent twisted the key otherwise it might be a nasty job. Is there any play in it when you wiggle the key? probably cos it hasnt been used for a long time. i suggeswt a bit of WD40 with the straw nozzle to get right in there. see if that works
Post by: alfie on 24 February 2010, 22:00:24
I,ve no key/lock on my passenger door,is that normal?
Alfie.
Post by: Andy B on 24 February 2010, 22:06:04
Alfie.
Yes! Your car is newer.  :y
Post by: Andy B on 24 February 2010, 22:07:12
Did you sort this out yesterday? All i could suggest is what you've already been doing, lots of wiggling of the key  :-?
Post by: ScaniaV8 on 25 February 2010, 08:12:24
Not sorted yet. I am currently working in Stockholm and car is in UK (still with key sticking out of passenger lock :-(
Back next Tuesday to sort this out and also get car thru MOT re-test (only failed on Handbrake efficiency last Saturday week :-(
Just wondering on re-test would they fail car again because of protruding key maybe seen as a dangerous item?
Post by: MutantCav on 25 February 2010, 08:25:18
Cant see why they would, your wing mirror sticks out a lot more and that wont fail the car
Post by: Andy B on 25 February 2010, 08:46:22
I think I'd lose the passenger side lock & find another same coloured passenger side handle to replace it with.  ;)
Post by: Mr.Salvador on 25 February 2010, 15:28:15
surely you would only need a new lock barrel to insert? not a whole handle?? take all handle off, seperate barrel from handle (possible have to cut key?) and refit new barrel into old silver handle. job done?!
Post by: Andy B on 25 February 2010, 21:01:05
My point being that it's a lot easier to replace the handle for one without a lock - ie like all the newer cars - than it would be to make another barrel fit the existing key ...... unless you wanted another key just for the passenger door!  ::)  ::) :y
