Omega Help Area => Omega Electrical and Audio Help => Topic started by: robson on 22 February 2010, 21:50:23
Title: Brighter bulbs
Post by: robson on 22 February 2010, 21:50:23
I was thinking of changing my headlight bulbs for the high intensity type. I can change the main beam bulb but I am not sure on the dipped bulb. Any advice please. 2003 2.6 V6 cd
Title: Re: Brighter bulbs
Post by: Andy B on 22 February 2010, 21:59:47
I'm not sure whether you actually mean HID's  :-/ Apart from all the legallities or not etc of levelling sensors & washers  factory fit HID's are only fitted to the dipped beam, because they don't react fast enough for the main beam eg for flash.
Post by: tunnie on 22 February 2010, 22:01:46
for standard projector lamps, Osram Nightbreakers are a good upgrade and give a decent improvement in light output  :y
Post by: mathewst on 23 February 2010, 09:50:58
I you are reffering to 100watt bulbs for the main beam do not do it.
Yes it will be better for you maybe till the cops catch you.
Plus you'll be blinding every driver from the opposite direction.
Post by: Andy B on 23 February 2010, 10:12:36
You swap from main beam to dipped beam for oncoming traffic, so higher wattage bulbs won't blind then per se, legal 60 watt are more than capable of blinding them if you don't dip  ;). I don't believe a copper has the power to be able to check up on the rating of lamps fitted  :-/.
More applicable for high power bulbs is whether the wiring is capable of supplying a 100 watt bulb.
Post by: robson on 23 February 2010, 15:13:04
Thanks for that. All I want to do is get a better headlight They do not seem to be very good at present I assume that I have standard bulbs at present
Post by: bri cox on 25 February 2010, 02:40:34
halfords do a 90 per cent brighter  bulb which are standerd wattage for 20 quid buy one get one free i got some for my rover sd1 they are a lot better then the standerd i can see the road now i going to change my high beam bulbs on my mig to the 90 per cent brighter
Post by: 2woody on 25 February 2010, 09:46:39
in the UK it is NOT illegal to have brighter bulbs in your car.
Post by: robson on 25 February 2010, 10:26:09
Bri cox It was the Halfords bulbs I was thinking about but I am not sure of the set up on my newly aquired facelift.  Are there two bulbs main and dipped . I dont think that they are double filament are they.  If there are two  I assume that you can change both but the Halfords book only showed one type available for the Omega
Post by: Andy B on 25 February 2010, 10:33:49
So, why do the 100 watt etc lamps have 'not for road use' on them Stu?
Post by: 2woody on 25 February 2010, 12:56:07
seemples :-
it IS illegal for a manufacturer to supply a vehicle with them fitted.
and it IS illegal for a bulb manufacturer or reseller to supply them.
BUT it is definitely not illegal to have a car which has them fitted.
Quote from the Road Vehicle Lighting Regs Schedule 4 :- "Wattage - No Requirement"
Post by: Andy B on 25 February 2010, 13:19:01
seemples :-
You live & learn!  :y
Post by: Entwood on 25 February 2010, 21:01:37
agreed .. but it IS illegal to have "unmarked" bulbs .. all bulbs must either have the "E" mark or a "BSI" mark
http://www.opsi.gov.uk/SI/si1989/Uksi_19891796_en_9.htm
Number 5
many bulbs sold on eblay carry no approval markings and are therefore illegal.
Post by: 2woody on 26 February 2010, 09:28:43
oh yes - it's definitely a requirement to have "E" or "e" - marked bulbs.
all of the bulbs you can buy will be approved - it's been a long time since I've seen one which isn't - and I do audit work on this subject on behalf of HMG.
the brighter bulbs such as 80/100's will be approved
