Omega Help Area => Omega Electrical and Audio Help => Topic started by: Dazzler on 07 March 2010, 17:38:50
As above.
If the CD is in use when you trn off the ignition, then it will go to CD safe next time you start the car >:(
any ideas??
Hmmm, assuming you have codes, pull the radio out for an hour...
Yes i have the codes ;)
Tis a strange one lol.
Will give that a go sometime.
You thinking it just needs a reset then?
yup, those ccrt700s do appear to regularly get in a state....
I`d pull the changer at the same time - reset them both
No harm in doing that as will, its only 1 bolt (7mm ?) that retains it :y
:-/ Mine's just a push fit into its cage behind the drop down panel.
You're missing a bolt, smack bang in middle of cage. Not really needed :)
Presumably on the long side :-/ :-/
If you drop the flap bit to reveal the cubby hole, you should see the hole in the side of the cage :y
Should be obvious if you check :y If not obvious, lift the changer out, you should see threaded hole (bolt goes through cage, thread is in changer itself).
Just braved the icey weather. Found it. :y Quite obvious when you're looking for it. It's never been fitted while I've had the car. :y :y :y
Bright sunshine here ;D
Just as well, have to get the Kawasaki ready to use for work tomorrow - she needs the Rover this week :'(
Same here, but still icey. I'd have to scrape the car if I was going to work. ;)
Very rare to find the bolt fitted !!
And for the record, its bright blue sky and 1 degree here -
But I`m still not allowed to go out to play yet, even if I wanted to.
Good to see you back .. hope everything went as well as you hoped :y :y :y
Thanks mate !
Everything went well, but recovery may take a lot longer than I envisaged - still hurts a lot.
But very good to be back though :)
