		Omega Help Area => Omega Electrical and Audio Help => Topic started by: griffin on 14 March 2010, 14:01:56
				Hi!
 Just need a little reminding, I want to remove the towbar electrics but I cant remember if disconnecting the battery is all I need to do to ensure the safety of the rest of the cars electrics.
 Sorry if this sound vauge.
 TIA
				Yep... That's plenty :y :y
 And don't forget to insulate any bare wires too ;) ;)
				Cheers Buddy!
 :y :y
				Cheers Buddy!
 :y :y
 Be aware that the white/grey 12S socket could very well have a permanent 12 v supply to it. Depends how it's been done as to where to pull its fuse. If done via the socket in the boot, it should just be a case of pulling one of the fuses from under the steering column.  :y
				Ok following my question yesterday. I'm hoping to remove the tow-bar and electrics due to the connector being smashed. Can anyone tell me if the black cable enters the car upbehind the fuel tank. It looks like it does but I've not had a chance to get under the car as yet.  But was hoping someone on here would know???!!
 Depends how the towbar fitter fitted it  ;) They generall come through the boot floor via one of the blanks near the back (bumper side) of the boot. YOu'll be able to see when you've removed the trim from the rear of the boot.  :y
				Cheers Andy B
 I'm hopefully doing this job tomorrow so I'll check then.
 I maybe back on if I get confussed!!  :D :D
