		Chat Area => General Discussion Area => Topic started by: Timbuk on 15 February 2008, 17:26:08
				Hire of a genereator for next weekend is as follows
 3.4 kva = 40 quid including my discount and vat
 4.0 kva = 56 quid including my discount and vat
 I propose we have 2 x 3.4 kva's at 80 quid + the portaloo at 53 quid including vat. If everyone who is coming is willing to pay 4 quid each it will cover the cost of hiring them and i will get them delivered on Friday afternoon and picked up on Monday morning.
 Your thoughts please
				Don't think anyone's going to compain about forking out 4 quid each Doug. Seems very reasonable. :y
 You obviously don't know EP that well Bob ::)
 £4 :o
 Id better start saving ;D
				I will pay £4 no probs.
 Do you need it Paypal ing to you so you don't have to stand out or do you want it on the day?
				I'll gladly contribute....
 How can i stand out when you keep posting that stupid picture of me sitting on my toadstool, everyone knows who i am anyway :D
 £4 :o
 They always say that it's the people who have got plenty of money are hardest to part with it!! ::) ;D ;D
				No quibbles here!  Well organised
				If we're going to be welding one big generator (pref. diesel) will be a much better bet than 2 small ones.
				No probs £4 is very resonable :y
				No issues from me :)
 Can't answer the 1 big or 2 little Q's though, esp wrt welding (someone needs welding :o)
				just a quick question about running stuff off a generator The camera gear i am bringing to film the different jobs is sensitive stuff what are generator's like for voltage spikes i dont want to knack my gear up as i have just gotten it 2 days ago. and would cost a good few thousand to replace.
 If welding is going to be done ill not run my stuff off the generator
 I could run it off and invertor i have but i dont want to end up with a flat battery.
 Craig
				Oh, BTW 4 quid is no probs. :y
 Craig
 A generator will be MUCH cleaner than an inverter. I'd say avoid having it plugged in when welding, power tools, etc. in use but when the gennie is just powering a bit of lighting it should be fine.
 Also, the reasoning behind a big generator is that ideally one that can power a welder plus a bit of lighting will do a better job. Otherwise, if you strike an arc with a welder whle the generator is unloaded, it won't respond quickly enough to the sudden increase in load (it has to increase throttle to maintain speed and that takes time) If it's got a bit of lighting load on it (and, being bigger, has more momentum and a bigger flywheel) it will already be loaded and won't struggle as much.
 Same principle applies with my geeky ham radio activities when trying to power a transmitter that takes a kW or two on voice peaks. :y
 Craig
 What about one of each then, We have got a lot of lighting to run?
 Craig
 If we've got more than 4kVA to run then that sounds like a winner. :y
				Better safe than sorry!
 an extra £1 each aint gonna break the bank!
 Craig
 Before we all bring shit loads of lighting, how much lighting do we need Timbuk?
 As for electronic equip of genny, the genny should have a filter/surge unit, if you can check Timbuk?
 Craig
 Before we all bring naff loads of lighting, how much lighting do we need Timbuk?
 I can check, but most of the stuff i get from this guy is usually pretty new, as for the amount of lighting, if we are working on 10 to 20 cars i would imagine everyone is going to want some sort of lighting with it being indoors?
 Does the unit get much natural light in during day?
 Yeah it does, plenty of it but as soon as it gets cloudy it gets pretty dark in there
 Right, so a fair amount of light may be needed.  Each of those halogen spotlights is 500W - I had a twin on a tripod (could be aimed to point at 2 cars), so thats 1kw, and a single one that sites on floor (another 500W).  The flourescent tripod uses next to nothing.
 I can bring another 2x500W on a tripod
 I can run an extension cable from the unit next door aswell which is what i am doing at the moment and im sure a lead light would be good enough for a lot of folks
				Kool I can run my stuff from your extention lead to be on the safe side i have a mighty long extention cable also with 4 plug sockets in it.
 But i have been also looking at some info on my camera gear the equipment can run from 10.5v upto 17v and has a total wattage of 25watts so on 12 volts it draws 2 amps which is nothing.
 The Camera Batterys i have are knacked and drain really quickly they are 13.2v 1.7Ah so a new bat will last for an hour
 I could hook my gear stright upto my car Battery in theory but i dont know if the car battery having 100Ah will be to much, or will the camera gear just drain what it needs if the gear only takes 2amps in theory the car battery should last 50 hours is this correct ?
 The reason i might go the extenstion lead way is i am thinking about recording this stuff stright to computer in the back of my car. and not bothering with tapes as on they are not cheap and two ill need to change them every 30 mins Betacam tapes are expensive.
 Oh ill be bringing two Big Studio camera for cut away shots and different angles so i might need someone to help as a second camera man or woman  ;D
 Craig
 Craig
 All your reasoning is sound :y
				No probs for chipping in with the generators.
				No probs chipping in for the gear EP's owe me a fiver anyway :y, I also have a halogen lamp on a tripod that I can bring along if needed 240v?
				Just a thought but would it be a better idea to wire the generator directly into the fuse board at the unit then all lights and sockets work without having to worry about lead lights?
 Assuming of course there are lights and sockets in the unit and its just a case of no elastictrickery being sent up the pole??
 I have no issues with chipping in for the hire fees either  :)
				no probs bout chipping in  :y
				No Problem contributing a bit of cash.
 with regards cameras and Laptops and such like, could I suggest an inline UPS???
 clean power with battery back up, so even if the genny stops for refuelling or breakdown, the camera/lappie doesn't....
 I have access to a reasonably chunky one..... if it's not out on location next weekend...  I'll check..
 what's going to be available for me to burn meat on??
				So, should we be going for one of each then ?
 Why not in for a pound in for a couple of pound ;D
 I agree.
				So, should we be going for one of each then ? Loo-Knee has got to have somewhere to plug in his Rampant Rabbit ;D
 And what about the squirrel ::)
 Thats got its own Duracells ;)
 Happy Days if Mrs. Loo-knee was comin ;D
 The Rabbits had it then ;D ;D
				No cause I have a spare 350 LC engine  ;D
 In that case the Squirrels in for it, better bring some of your Viagra for the squirrell ;D ;D
 ;D ;D ;D ;D
 The poor squirrel has been at it none stop for 18 months ;D
 He is the Topman ;D
 He is the Topman ;D
 Topsquirrel you mean :y
				Just as a matter of interest, you are still talking about a meet to work on Cars are you not? ;D ;D
 Off course we are..... you really need a trip to Spec Saver ;D
 Some people I just don't know ::)....did'nt you say he could'nt read anyway ::)...that'll be why he is asking ;D ;D
 LMAO, if it ends up anything like your last trip, then i am all for it ;D ;D ;D
 Has Daz been to specsavers too then ::)
				Just as a matter of interest, you are still talking about a meet to work on Cars are you not? ;D ;D You know how it is Steve, work on cars, rip the p**s out of "not quit a newbie" eat barbeque, get drunk & rip the p**s out of him again. ;D ;D
 so whats new people need someone to bully and take the p**s out of, unfortunatley it seems to be me :'( :'( :'(
 Best be careful, he's currently being preened for moderatorship ;D ;D
 The only way Daz will become a mod is to buy a vespa and a parka with a target on the back. ;D ;D
				Well said John :y :y
 It sounds like its going to be fun, shame i can´t make it, are you going?
 Indeed we are, should be a good laugh.
 LMAO ;D ;D ;D ;D ;D ;D
 You better PM Jaime and tell him then before it's too late :y.....Oh and cc the PM to Loo-knee aswell just to keep him in the loop :y...cos he can't reply anyway ;D ;D ;D....PMSL
 Back Stabber ;D
 Back Stabber ;D
 Sorry I forgot you prefer Lambrettas.  ;D ;D
 Canty canty custard, cover yourself in mustard ;D
 Back Stabber ;D
 just can't trust them northeners can you Daz ::)
 Back Stabber ;D
 Well I don't know about trusting Northeners most seem fine, but the Captain is a little suspect :-? has he told you about him and his mates dressing up and holding hands in pubs?? No I bet he ain't ;D
 He asked me to keep it quiet, I gave my word but i had my fingers and legs crossed ;D
 Back Stabber ;D
 It was'ent that quiet it was in the evening paper
 :P :P :P
 Back Stabber ;D
 Your supposed to do that when you go in a pub like the "Flying Handbag" aren't you?
 Cmon Daz you must have been in a few in your time.
 Back Stabber ;D
 :P :P :P
 To raise money for
 Special Care Baby Unit
 Back Stabber ;D
 :P :P :P
 To raise money for
 As my older son was in there, as he was 3 months early
 2lb 7oz
 Back Stabber ;D
 Wot happened when you went to the toilet then ;D ;D
				Now look Tigger, I now your married to this Suspect Man, but please try and make up a better story than that ;)
 I'm not making it up
 We where both dressed up see the pic on left that was the night
 Well everyone in the pub was dressed up
 He was wearing make up I could'nt tell the diferrence
 That makes sense then, Daz is right ::)
 Back Stabber ;D
 Well this just goes to show, how much of a slapper our young Daz really is.
 If you want a secret to make it world wide, then he is the one to tell ;)
 lets just hope that he stays that way ;D ;D
 I did not write that you cheeky bastard
 I did not write that you cheeky barsteward
 Just can't trust those northerners can you, messing with folks threads ::)
 I am always right, as we speak I am getting messages "Please don't mention that Daz, I will PM Jaime and beg him to give you back your Posts!"
 Well my cross dressing, lipstick wearing, flying handbagin friend, bribery doesn't work with me ;)
				LMAO whats going on here, keep it up ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D :y
 I always knew you were right Daz, never doubted you for a second mate :y..................Anyway what the break has all this got to do with the price of a generator ;D ;D ;D
 Are you tellin me with your proclivities that you've never been in a gay bar.
 He may have been in a field though, not sure who else was there with him though ::)
 (http://i85.photobucket.com/albums/k65/mickdundee_01/LOOKNEEPINKY.jpg)
 give us a kiss and I'll tell ya ;D
				LMAO :y :y
				It's all coming out now ;D ;D
				I have been in some fields i can tell ya, flatterned some grass in most of them too, thats what happens you see boyz when your gifted in the looks department like me...
 So Countess thats the first true thing you have said all afternoon ;D
				All started when Daz asked me to recommend a pub to visit for his hols in Blackpool, I recon the Flyin Handbag would suit him down to the ground.
 It's very pink too.
 It was funny my mate's husband got chatted up
 ;D ;D ;D
				Oh god I am gonna chuck, what did I tell ya  ;D
				Oh god I am gonna chuck, what did I tell ya  ;D Hey Zoe was very nice, think she called herself George through the week though. ;D ;D
				Oh god I am gonna chuck, I remember telling you now ;D
 Ahh this should be interesting, what did he tell you then ::)
 Ahh this should be interesting, I was there then too ::)
 I really am getting worried about you to Countess, especially when you want me in the back off your car  ::)
 Well I know I shouldn't divulge a confidence but, aparently Daz wants to be known as "Princess Dazrina" at the weekends, says he's tryin to get in touch with his feminine side. :o :o :o
 :o
 Now what were you doing in the back of his car in the first place :o :o
 Back of what car, never mentioned anything of the sort ::)......By the way how's Mrs Loo Knee ::).....still got those mates in your back pocket :-*
 Tunnie is going, so we'll be ripping the mickey out of him as well.... ;D
 Can this meet get any better? ;D
 So you didn't say this then??
 "should really be cleaning the car, but think I'll leave it till Friday, seen as on saturday your gonna give me a hand to change that sunblind in the back off my car!"
 what do ya mean him as well, thought you said "Us Moderators stick together!"
				Your going to be a newbie again very soon ;D ;D
 Remember, foreskin ear warmers before that happens ;D
 He may not come now ::)
				You all know how touchy Daz is, i honestly cant understand how you could trample on his feelings like this ::) ::)
 Ermm, was'nt it you that started this ;D
 that triggers terrible pain inside my head and i have now crossed my legs :o
 You been doctoring my threads again :P
 I would never dream of such a thing :o
 Well you must have sent one of the admins a PM to doctor it then ::)
				Mike thats how I lost my post Count I would Hate it to happen to you ;D
 [size=20]JAIME[/size]
 Ey up we're on best behaviour now Daz, you even spelt TB's name right. ;D ;D
 Ahh thats how it all happened then, thanks for warning me :y
				Mike
 What was it I was going to do do with wax and feathers
				Mike
 Well he'll soon find out next week if he turns up :y
				I would be happy to stump up a few quid for a generator.....
 .....or is that not what this thread is about  ::)
				Mike
 I found it
 its in Whiping loo knee
 :y :y :y
 Yep, me too
 Yep, me too
 I think I said yes, but can't find my post now, so confirming again.
 Yep, me too
 One of each then?
				i'm happy to bung a fiver in the pot, i'll also bring a few beers with me :y
 Yep, me too
 One of each then?
 I said yes too, so did AA and a couple other members, apologies timbuk as i think your post got hijacked by a Newbie ;D
				No probs chucking in a fiver mate.
				£5 no probs with me Arthur :y
				No probs contributing to the cashpot.... :y
				As I said before, no probs contributing.
				The Boy wares dress's at weekends! , brave considering all this post count business going up and down like a Yo yo. any way nothing wrong in dressing up says me Zirk, and Zirka at weekends.
 If I get a few hours free I may turn up next weekend for some advice, wots the penalty charge for just watching.
				£4 is no probs  :y
				Two generators ordered today, will be delivered on Friday afternoon with the Portaloo. I finally managed to get my portakabin inside the unit today after it standing outside for a month :-/ Good news is the radiator works in it, i wonder which part of the unit is going to be the most populated ::)
				good news doug :y
